Question about Epson Stylus C46 InkJet Printer
RED le d continues blinking
Cartridge holders do not move ?
    Problem Solver:
  • 3 Answers
Try with re-installing the driver
Posted on Jan 22, 2009
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
Green light flashing and ink replacement light flashing red - when you press the button the cartridge holder will not move to the centre to allow it to be replaced
Hi!
Try to look for a ruler or something that will make you press the cartridge cover fully. It may be loose or not snap in properly thats why the cartridge holder won't go all the way.
Hope this helps.
May 05, 2011 | Epson Stylus 680 InkJet Color Printer
Tow red signal
  1. Make sure the printer is turned on, then open the printer cover.
  2. Do one of the following:
    • If the red error light is on, press the Maintenance button.
    • If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
  3. You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
  4. Open the cartridge cover.
  5. Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
  6. Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
  7. Close the ink cartridge cover.
  8. Press OK and close the printer cover.
    The printer begins charging the ink delivery system.
  9. When you see a message that charging is complete (after about a minute), press OK.
Dec 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
Blinking red light
You have a cartridge refill
The fuse is 250mA (250 volt but this is not critical) go and 315mA. The fuse is 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge they are inside the printer. There is a plastic fuse holder on the cartridge, even the starter cartridge. If you face the cartridge with the green roller horizontal and down, the fuse holder will be on the right side just above the phillips screw and in front of the white gear you can see inside the cartridge. The fuse installs horizontally, (in line with the green roller). You just simply pop it into the holder. (I wish I knew how to post a photo, it's really easy when you figure it out.) This will stop the annoying flashing red LED and your system tray will say the cartridge is full. Good luck!!!
Oct 10, 2009 | Samsung ML-2510 Laser Printer
Red light keeps blinking. How to stop it?
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Aug 08, 2009 | Samsung ML-2510 Laser Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
PAPER FEEDER SOUND AND LIGHT IS BLINKING
when you turn it on, the ink cartridge holder should be moving left to right (aligning itself). make sure the cartridges are insterted correctly and that the clasps are all the way in.
Jan 10, 2009 | Lexmark Z600 InkJet Printer
Samsung ml-2850 Blinking Red Light
Change cartridge chip r paper pickup sensor
Nov 15, 2008 | Samsung ML-2510 Laser Printer
Blinking Red Light
unplug your printer
try to move the ink case manually.
if you could remove the ink cartridge, then clean the contacts both on the cartridge and case. return the cartridges then move the case to its original location
plug
Nov 06, 2008 | HP PhotoSmart 7660 InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
Epson Stylus C46 InkJet Printer Logo
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
