Question about Zanussi TC7102W Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
I need to know what my Kenmore electric drying has wrong?? It blows cold air only.......Its a Kenmore 90 series electric dryer....
  • kukyvivi Jan 15, 2009
    I need to know how to check breakers,check element,How to remove the top to check thermal overload switch...................This is all new to me.....I'm a single mom with no clue on this subject...
  • 979 Answers
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
  • Bill Dickerson
    Bill Dickerson Jan 16, 2009
    Your best bet would be to call your local appliance repairman and let him look at it. While he is there, have him show you the breaker panel in case something else in the future should give you a problem. If you can, use the company you bought the dryer from in your town or city. It may cost as little as 50-75 dollars to look at. He can tell you the approx cost. Then at that point, you can decide to either have it fixed or buy a new one. A good rule of thumb is if the dryer is much older than 10-12 years you would be better off getting a new one. Lowes, Sears, has a good one for about 350-400. They do have financing if needed. I am sorry I can't be of more help, but this may be your only alternative at this point. The best of luck
  • Bill Dickerson
    Bill Dickerson Jan 18, 2009
    Have you had a chance to call the repairman? Let me know how you do on this.
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Fuse out on kenmore electric dryer 90 series
The fuse on most Kenmore series dryers is located on the blower housing where the squirrel cage is that blows the air out of the back of the dryer.
Apr 21, 2012 | Kenmore Dryers
The dryer runs but only blows cold air. It's a gas dryer. Kenmore 90 series
Have you checked the igniter yet or tried replacing it?
It is generally the first thing to go when this happens.
Benjamin
May 24, 2010 | Kenmore 73952 Gas Dryer
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Zanussi TC7102W Electric Dryer Logo
826 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
