Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Door Won't Open or Close with Motor
Our garage door wouldn't close today, so we closed it manually. Now we can't get it back working with the button at all. Could it be off track? Is there a way to reset? A secret button? Thanks
  • marty metzger May 11, 2010
    Have no idea what you mean when you say "the Button". A wired wall button or console; a remote control, Need further info. What model, how old
    Champion:
  • 244 Answers
You give nothing to work with. How old is unit. what brand? off track=no. way to reset -maybe OLD units have reset button on back panel (35 yr old_. Did you overheat by trying too many times. Wait 15 minutes for motor to cool and it will be ok. If none of this, provide more info (PS - is power on)
Posted on Jan 15, 2009
  • marty metzger Jan 15, 2009
    if there is a secret button and i tell you, it would not be secret anymore. you need to provide better description of what is or isn;t happening,
Garage door will not close
Make sure nothing is blocking the sensors on the floor at each side of the door.
Aug 23, 2013 | Building Materials
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Aug 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers Tom
I have the same problem. Door does not open or close when press the push button and/or transmitter. The light flashes 5 times. Manually open or close the door is ok. On the manual troubleshoot, it says it's either the opener is overheated or it's on vocation mode. I don't know how to switch of vocation mode. Is it possible the thermal sensor is broken?
Can someone help?
Jan 28, 2011 | liftmaster Electrical Supplies
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
151 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
