Blows 4 amp fuse inside tv
Keeps blowing fuses
  • 70 Answers
The poer supply faulty. Isolate Horizontal output stage from the power supply and connect dummy load (like normal bulb same wattage as TV ) and test. before that pls check all component in power supply and replace and burnt parts spacialy diodes caps and power regulater ic as well
Posted on Jan 15, 2009
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Blowing fuses keep
Could be a short in the circuit board inside the speedo cluster. Does the fuse blow if the cluster is unplugged ?
Jul 25, 2014 | 2001 Chevrolet Chevrolet Blazer
LC320EM2
If it blows when turned on a short usually on the secondary side of the power supply---its the part or area where the voltages that are developed are distributed to the rest of the set.
One other odd thing can happen---say a 5 amp fuse is blowing, you go out and buy a generic fuse of same value--at like Radio Shack etc.
Many of the fuses used in modern gear will blow instantly if not the original type and made for that unit.
I had one customer who had a 4 amp blow every time he turned it on--generic fuse-----The correct fuse of same amperage did not do that.
Don't keep feeding it fuses as if a short sooner or later parts that are not now bad will get destroyed and make matters much worse.
Dec 08, 2012 | Televison & Video
94 Jeep Grand Cherokee 4x4 with the 4.0 Keeps blowing the fuse that controls the fuse box inside the jeep, its blowing a 40 amp fuse. I believe there is a short. but i don't where to look.
Get yourself a set of factory wiring diagrams,
otherwise your wasting your time
You have no idea what you working on, without
reference material
Helm.Com
Jun 20, 2012 | 1994 Jeep Grand Cherokee
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
May 13, 2008 | Panasonic CT-36SL13 32" TV
Blown 4 amp fuse twice
ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Sep 14, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
The tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Aug 14, 2007 | Sylvania 6432GG 32" TV
Televison & Video Logo
393 people viewed this question
Top Televison & Video Experts
