Question about Dell Inspiron B130 Notebook
My Dell Inspiron B 130 laptop computer is running hot
The heat is coming from the left rear (me facing computer) near the thermal module. After approximately 30-40 minutes the computer will cut off and sometimes it will give an error message (m1004).
I know that I need a fan because I don;t hear it running, I need to knoiw the serial number of the fan and the screws to remove for access.
    Sergeant:
  • 366 Answers
From Dell service manual
The Microprocessor Thermal-Cooling Assembly
No detail found on part number in Dell component web site
Try using actual component part #.
Posted on Jan 15, 2009
  • 827 Answers
Dell Inspiron B130 Fan Assembly GC055515VH-A - 0MD538
http://www.lapzone.com/servlet/the-1624/GC055515VH-dsh-A--0MD538-/Detail
If you take of the bottom panel, it should be as simple as unscrewing the old and replacing them in the reverse order.
Hope this helps
Chris (ziraffa)
    President:
  • 2,692 Answers
Fan won't stay on
try one ram at a time.
trying cleaning all fans.
check heat sink paste on your processor to make sure you are not over heating.
Jan 27, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
My Dell INSPIRON goes very hot and shut down after a while
FIRST CHECK LAPTOP RUNNING OR NOT
DONT USE LAPTOP ON BED
DONT USE TABLE CLOTH UNDER LAP
CLEAN THE HEAT EXTRACT AREA WITH AIR PUMP
CHECK ALL DRIVERS INSTALLED OR NOT
Mar 03, 2013 | Dell "Inspiron 15 R 5110 Notebook, Intel...
Dell inspiron n 4010 hangs often
I suggest you open the laptop, and clean it out first. THEN go on with the diagnoses.
Dell Support > Inspiron n4010 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insN4010/en/sm/index.htm
1) FIRST remove all power. Remove the AC adapter (Charger) and Battery.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components on a computer.
Relieve your body of Static.
You should use an ESD wrist strap, and connect it's alligator clip to a good ground source.
This is an example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
This pictorial guide for disassembly of an Inspiron n5010, should help also.
http://www.insidemylaptop.com/taking-apart-dell-inspiron-n5010-inspiron-15r-laptop/comment-page-1/#comments
The screws, and cables, etc., are in a different place, but disassembly is still the same.
Use a can, or two, of compressed air for computers.
Also you may wish to use Q-tips, and a soft small brush.
(Makeup brush? )
DO NOT use a vacuum!!!!
A vacuum creates Static electricity.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 15, 2012 | Dell Inspiron 14 Laptop Computer (Intel...
Dell inspiron shuts down
Check that the machine is not running too hot as this will cause the system to shut down to prevent thermal damage.
Mar 14, 2012 | Dell Inspiron 1525 Laptop Jet Black
Have an Dell inspiron e1405 laptop. Screen is not
Try new memory (RAM) or if the device has two memory module install turn the deviice off take one module out turn on
If it does not work then
Turn the device off take the second module out replace with the first module
Turn the device on
Jan 06, 2010 | Dell Inspiron E1405 Notebook
Over heating of my DELL INSPIRON 1420
check processor fan and use extra portable laptop fan.
Jun 01, 2009 | Dell Inspiron 1420 Laptop
The fan could be faulty (ie stopped spinning) or the heatsing vents are clogged with dust.
Remove the fan and check/clean the vents/fan. If the fan is faulty replace it.
Mar 13, 2009 | Dell Inspiron 1420 Laptop
Inspiron 5150 fan continously running
Dell Inspiron 5150, has overheating problems. The position of the fan is a problem.Also,don't press of the left upper corner of the laptop.Here's an excerpt from a wikipedia article: "The overheating problems on the Inspiron 5150 model was due to the position of the fan and fan-vent and the way in which it vents air through the CPU's heatsink.[citation needed] The fan draws air from underneath the unit and vents it through the rear after passing over the heatsink. However, the unit also sucks up dust from underneath it. Over time a buildup of dust constricts the airflow through the unit, reducing cooling. The airflow is perceptibly diminished. A simple test is to place a hand near the fan vent; when the fan is running at high speed there should be a good flow of warm air. Heat will also build up along the top of the unit near the LCD display and left toward the optical drive. Users may notice this while typing. Performance may also suffer, with jittery game movement and slow Windows performance. Some systems may experience jerky reactions where the unit goes into an almost slow-motion phase for short periods of time. Continued operation in this condition may lead to overheating and could result in permanent damage to the CPU, GPU, motherboard and other internal components. To remedy this the unit must be disassembled, the dust removed, and fan operation checked. This problem not uncommonly results in a CPU temperature-increase of between 15-20°C over an normally functioning unit. Further temperature increases may damage the casing of the unit."From Wikipedia article"Dell Inspiron" under problems Hope it helps -CG
Jan 20, 2009 | Dell Inspiron 5150 Notebook
Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Jun 14, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
340 people viewed this question
Alun Cox
