Question about RCA P52920BL 52" Rear Projection Television
Tv signal scrambled then pop and now just a beep
Watching tv and the tv scramble similar to a signal error then came back and then went black, and now all i hear is a beeping sound, all suggestions helpful
  • sam sam Jun 15, 2007
    any idea on the cost to fix or is it time to just buy a new one
    President:
  • 3,130 Answers
You have it sounds like a bad flyback transformer as well as a bad horizontal output transistor. Not a job for the novice or user. good Luck
Posted on Jun 15, 2007
  • Larry  Dillon
    Larry Dillon Jun 15, 2007
    If the set is over 7 to 8 years old, no Most likely be best to get another set
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
It says I need code to get some stationd
This could be caused by your channel receiver picking up a new channel, like a scrambled sky channel.
Do you have a standalone receiver like, MYSky or Free-view, Dish TV or similar.
These usually scan for new channels occasionally and find channels that need codes or are scrambled.
Maybe you have a content lock on the TV to prevent the viewer from accessing some channels.
Feb 11, 2014 | Toshiba 65HM167 65" Projection Television
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Jul 05, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Tv when turned on starts out great. After a few minutes starts to scramble the picture in a manor you cannot make out what your watching
The tv the Tuner board,the board where the coalax cable broscasting signal come in and connected to this board,it defective.Tries websites like Shopjimmy.com.Ebay.com to buy a refurbish Tuner board for the replacement,will solved this problems.
Jun 15, 2010 | Westinghouse 32" Flat Panel LCD HDTV
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
E16 service is currently scrambled
Hello! try this  check if the card is activated connection  signals  ,swap it with the old one just to make sure the card is good or bad .
Ask the Satellite firm technician come do signal set up for u .
 good luck
Sep 19, 2009 | Televison & Video
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
