Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffe residue inside coffee pot
How do I clean the inside of the coffe pot? There is kind of a film in the coffee and in the inside of the pot. It looks burnt inside the bottom of the pot. I've tried vinegar and water...lemon and water. I've run the maker with vinegar and water. Please help.....
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
Posted on Sep 27, 2009
I have put mine in the dishwasher. usually 2 times through and it's clean. You can also try BON AMI as it is save to be used on cooking items, just make sure you rinse it thoroughly.
Posted on Mar 12, 2009
    Problem Solver:
  • 7 Answers
One thing you shouldn't use on this is bleach! I cleaned my thermos out with bleach and it no longer insulated. The stains inside were gone, but the outer surface was hot after I refilled it with coffee. That was my favorite thermos-over 10 years old, but you must go on...LOL.
Posted on Feb 18, 2009
White residue staining dishes and pots and pans. Have cleaned with dishwasher cleaner and it still is ruining dishes.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 17, 2011 | Dishwashers
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
How to clean the coffee pot
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 25, 2010 | Bunn 10 Cup Home Coffee Brewer
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Hi there, i have a problem with my Oscar coffe machine. Is not creating enough pressure at the coffee pot part but highr pressure valve pops out after 10-15 sec of running.It looks machine pumping pressure...
sounds a if your heating element isn't being allowed to generate enough hot to send the hot water up the pipe, see most coffee makers do not actually pump the water, what happens is that the water passes through a heater that rapidly heats the water causing steam to push some of the water up the pipe(also creating the popping noise you hear), if the pipe is coated with residue from the water(most water has calcium and other mater which is deposited on the pipe walls during rapid heating), you need to do a cleaning cycle either using a commercial cleaning solution made for coffee pots or you can run some vinegar through it stopping for a few minutes about half way through the amount you are using to allow some of the vinegar to dissolve the residue from the pipe walls. that should clear up the problem, you should clean it at least every couple of weeks to keep it running smoothly
Dec 07, 2009 | Nuova Simonelli Oscar Coffee Maker,...
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
I have a cooks coffe maker (from JcPenny) my coffe
Wal-Mart,  BI-mart, Target, K-mart those kinda stores usally have them. or you can find the cook web site and try that.
Apr 20, 2009 | Cook's Essentials Cooks Essentials Arome...
Delonghi coffe pot DC312T --can't find a replacement carafe. Sams Club doesn't have them anymore.
I threw out the coffee pot. The replacement carafe was more expensive than the entire coffeepot!
Apr 17, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
TAKE 45 MIN TO MAKE A POT OF COFFEE
you said you clean it you use vinegar or decalcifier vinegar remove calcium in piece it might block the orifise if you use decalcifier it melt the calcium 1part solution to 1 part water dont forget to rinse very good that stuff is nasty cheers
Jan 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
315 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
