Question about RTO TPI G3482 Commercial Recess Mounted 6,826 BTU Ceiling Heater Power: Phase 1
Propaneheater pilotlight keeps going out
Where U work we have 2 laundry rooms ,last year the pilot light kept going out due to moisture in the tank ,well the other one is acting up .I cleaned the whole unit , a local company came in and changed the high limit, ,checked the exhaust venting ,they said the gas valve is ok. my boss said they think there isn't enough outside air, the vent is directly behind the unit and it was open about 3/8 of inch , which it has been for about a year and a 1/2, they say its also because of the 6 dryers , but the room isn't used that much. my opinion is it goes out everytime we have really cold weather and we are again getting condensation in the line with a 1/2 filled tank / how close am I to possibly being correct .? should an additive be added to the fuel tank .? let me know a.s.a.p. please
  • 3 more comments
  • rlghandyman Jan 15, 2009
    the type of heater isn't exactly that brand but its close ,the heater is good but think its the fuel/h2o
    what are the problems with moisture in the fuel,how do you know ,symptoms
    thanks for answerind me so fast ,as far as the thermocouples, they did replace that, not saying its any good you never know as far as the air flow the vent was in the same position for who knows how long , if its ill-positioned who knows how long it would take to go out , our 's stays on for about a week sometimes a little less
    also the technician thinks its the dryers and the heater fighting for air dryers take it from the heater, everything is open and the dryers work fine and when I;m in there they both are great, the dryers may not work all the time the people don't always tell us everything
    the chimney was the first thing the tech checked, the exhaust tube comes off the top of the heater which is mounted directing to within 6 inches of the ceiling, and no landscaping has been done. the front cover is always on . last year we had an additive put in the fuel with a very similiar problem and it corrected it right away. but the fuel filters ,well there are't any and thats what we 've been discussing also.
    President:
  • 2,976 Answers
Thermocouples are either good, or bad. When the pilot stays lit after relighting, the thermocouple is good. I would suspect a downdraft problem. Has any chimney work been done? Do you have some of the exhaust tube (at least 3 - 4 inches) protruding into the chimney? Have you done ANY landscaping that could change the way air moves across the exhaust? Make sure you have the front covere on. It will prevent drafts & gusts from blowing the pilot out. Moisture in the tank shouldn't be a problem. The moisture will settle on the bottom of the tank but you draw your gas from the top. Make sure your fuel filters are all clean. They should be replaced every year. They are relatively inexpensive, compared to down time.
Posted on Jan 15, 2009
  • David Shaub Jan 16, 2009
    It may sound stupid but, something as off the wall as a bad door closer could blow the pilot out. If you have a door that shuts faster than it used to, it could be creating a puff of pressure when it shuts. Slow it down and see if that helps.
    President:
  • 2,692 Answers
If you have a breeze, that can blow out a pilot.  If the thermocouple is weak or ill positioned(the pilot flame not in the center of the thermocouple rod), that will cause it to go out. Mosture or water in with the gas, insolate part of the line or see you supplier about why it would have mosture in it.  I donrt; know anything about additives. I would go with redirecting the outside air to avoid drafts.
I have had a lot of weak or bad thermocouples that caused the pilots to go out . They are cheep . Replace it.
Pilotlight will light, but goes out when i turn knob to light burners
sounds like you just need to hold it to the light pilot position a little longer . that heats a thermo couple that keeps the main burners on .
Jan 05, 2015 | Heating & Cooling
We have a residential Lochinvar Solution Boiler (model RBN090). Around 7 years old. For past 2 weeks pilot light keeps going out. 2 repairmen have come out. We have replaced the Gas regulator, the roll...
Take notice of the wind conditions when it goes out. If there is a draft, the wind can come in the room with the water heat from the flue and blow it out. Or it can come in the room from another way and exit from the flue and blow it out.
May 12, 2017 | Heating & Cooling
Cannot light pilot on 4 year old heater rheem tells me part not available in supply house is this right part i need isvile that is broken below pilot light
I can't tell if you have tankless or tank heater.
Rheem has gone big into tankless the last few years and maybe first models don't have parts any more.
Even so, Rheen probably sells the whole burner assembly.
Most plumbers prefer to replace whole assembly so they're not doing a call-back next month.
Check with Rheem for whole assembly.
Another option is to roll the Rheem heater out of the way and install generic brand from Ace, Home Depot, Sears, or Lowes. Read manual cover to cover to prevent failure. Keep dust, lint and chemicals out of same room. Loosen anode rod before installing. Connect ground wire jumper to hot and cold pipes.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Fix the Rheem when parts become available, or use it as tempering tank to passively preheat incoming cold water, or set tank in wood box with glass cover and make passive solar tank.
Feb 14, 2011 | Rheem Water Heaters
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Pilotlight on gas water heater went out. cant get cover off to light pilot light. Heater is three years old.
Some of the modern heaters have covers that are not removed to light the pilot. Look for an external "clicker" type spark ignitor.
Usiually a red button. Sometimes integrated into the gas valves on/off switch.
Dec 06, 2008 | Heating & Cooling
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Blodgett 961-P pizza oven
Go here find what you seek.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Great Co.
Sep 30, 2008 | Blodgett 911-DOUBLE Gas Oven
Crtl key not working. Possible due to moisture?
if u feel the moisture is the case put ur laptop under 500watt bulb in a shut down mode...like under a lamp or so
other wise chk th manuls open the keybrd panel and clean the key properly
Jul 11, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
RTO TPI G3482 Commercial Recess Mounted 6,826 BTU Ceiling Heater Power: Phase 1 Logo
56 people viewed this question
Top RTO Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
Steve
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
