Question about Eagle Fishelite 642c Color Fishfinder Gps With Internal Antenna
No backing light
Eagle 642c the backing light has failed only 14 months old can this be repaired? thanks
Eagle only gives out a 1 year warranty on their products, so as far as I know you wont be able to get it fixed for free, but I would email them and see what they say.
Posted on May 22, 2009
Does not show depths on lake map anymore
try your zoom button zoom in see if the depth shows up
Oct 12, 2013 | Eagle Fishelite 642c Color Fishfinder Gps...
Eagle 462c will not power up
I called Lowrance and since Eagle has been discontinued, they no longer service them. However, they will offer to upgrade to Lowrance. I ended up getting a HDS-5 for $480.00. Not a bad deal since my Eagle was toast.
Sep 29, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
I hit menu and it comes up but i hit it again for main menu and it just goes back to screen i have no main showing
Reboot procedure from from Eagle tech support:
1. Turn unit off
2. Press and hold pages key
3. Press and hold power key at same time
4. Unit will power up. Wen map appears, release both keys.
5. Press exit 3 times
6. Press the menu key twice and it should now access the main menu
May 30, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
My Eagle 642C iGPS does not work with Lakemaster chip
If you do not have the most current software upgrade, that may be the problem. Go to www.eaglenav.com. If a more current software is available, download per their instructions. Worth a try. That unit should display LakeMaster digital chars.
Apr 04, 2010 | Eagle Industries FishElite 642C iGPS GPS...
No back lighting and screen blinks. Purchased exactly 2 yrs ago
Sync lock transistor is faulty here. and i agree Lowrance units are unreliable and their service is soemthing else!
Aug 19, 2009 | Eagle SeaCharter 642C DF iGPS
Backlight flickers 2 years old to the date do you
Furuno has similar displays. I don't know if Eagle provides the same support but you may be able to find an actual schematic diagram technical manual from them if you ask nicely i don't know if Eagle has any government contracts but you can try and tell them you are with some government agency like DOD navy or coast guard or homeland security ;) and see if they will send you a PDF of the manual also try Retrevo.com they may have the techmanual on file. It sounds most likely like a connector problem between the LCD and the power supply. Does it only happen out on the water (vibration or shaking)?
Eagle Seacharter 642c back light flickers all the time
Mine did the same two weeks out of warranty and I was told by NAVICO, the Australian importer and repairer, to throw it in the bin as the whole unit would need replacing, thanks for the expert advice NAVICO. It will be the last Eagle/Lorance product I will ever buy.
Jun 19, 2009 | Eagle SeaCharter 642C DF iGPS
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
Marine GPS
change the antenna with new
Jan 12, 2008 | Eagle IntelliMap 500C GPS Receiver
Eagle Fishelite 642c Color Fishfinder Gps With Internal Antenna Logo
266 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
