Question about HP OfficeJet 7410 All-In-One InkJet Printer
Fax cover sheet
Ive downloaded the soft wear but didnt get any desk top icon to controll the 7410 all in one and cant find it on a search
    Sergeant:
  • 366 Answers
Assuming you are on XP:
Start/settings/Printer and faxes
Right click on your printer icon and select "printing preferences"
Posted on Jan 15, 2009
Put facebook on my samsung galaxys 5
There is a Facebook App that you can download using the Play store icon. Just enter Facebook into the search bar and follow the prompts.
Oct 10, 2014 | Samsung Cell Phones
Im trying to fax but my paper to large how the i use the top printer?
Send a fax - Use the control panel and scanner glass 1. Make sure your All-In-One is on. 2. Open the top cover. 3. Put the first page of your document face down on the scanner glass in the upper left corner. printmastert_34.jpg
4. Close the top cover 5. On the control panel, press Fax. 6. Enter the fax number, then press black or color to send.
Use the control panel and ADF 1. Load up to 50 sheets of your original document face up in the ADF. printmastert_35.jpg
2. On the control panel, press Fax. 3. Enter the fax number, press black or color to send.
Apr 08, 2011 | Lexmark X6170 All-In-One InkJet Printer
I can only print black but i need color also
1] The first step is to get into your computers' control panel, go to the start button on the desk top and click it, then go to settings and click on it and control panel and click on that.
2] Once your in control panel you'll see the printers and faxes icon you'll click on that.
3] You'll then right-click on the icon for your printer (i.e the printers' name and model) and go to properties selection which will bring you to the property sheet.
4] After that you see (depending on the OS) a number of tabs for that particular printer, usually it will be labeled setup, color management, etc, you'll select this.
5] The final steps are to select the color radio button instead of the black button and to finally close out all the windows of control panel to get back to the desktop.
6] Now your printer will be printing in color.
Regards
George
Jan 14, 2011 | Computers & Internet
How to program telephone numbers to memory?
Press
Function
72
set
press 1 for 1 touch numbers
press a soft pad key such as 01
enter fax number
set
enter name
set
press 02 soft pad key to continue or STOP when you are done
press
function
67
set for a directory sheet to cut and place under the mylar soft key cover
Jan 20, 2010 | Panasonic PANAFAX UF-6000 Fax
I have a thomson roc1404 and cant tune into tv / ive lost the manual were can i download it date code 1633
You can find a soft copy on Diplodocs. I've done a custom search and here is the link:
User manual THOMSON ROC 1404
When you click on the above link, a page will open. Look on this page at the top right corner, you'll find the download link.
Jan 12, 2010 | Universal Remote Control DIRECTV Universal...
I cant download internet explorer, I want it to have an icon on the desk top, awhile ago I have an icon on my desk top with a a symbol e but I dont know what did I do, it was deleted. while opening my i...
To put a shortcut on the desktop, simply click Start and then find Internet Explorer, left click and drag it to the desktop. It will create a shortcut.
Oct 06, 2009 | Microsoft Internet Explorer 8
Explane how to use fax.
It is similar working on ur phone . Switch on ur fax machine. dial the destination no. . With the cover sheet at the top arrange other sheets carrying the information under the cover sheet in order and feed it to the fax machine feeding tray . The cover sheet is one which contains the recipient identification and ur identification in it
Mar 08, 2009 | HP Officejet 4355 All-In-One InkJet...
Always feeds a second sheet
You may need to repalce your pick-up roller and your stop roller
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet 7410 fax failure
Had the same problem as everyone else here - would copy fine but faxing or scanning resulted in the "whizzzzzz" sound (with or without the sheet feeder) and a mandatory reboot.
I followed the suggestion of moving the scanner head to a different part of the drive belt and it works fine now (at least until that part of the belt wears down!). Here was the procedure - it took about 10 minutes.
  1. Remove all T8 screws from the top of the scanner bed - there are two hidden on the left side under the removable flap and two more hidden behind the front control panel cover, which just snaps off.
  2. There is a bundle of wires that prevents the entire top from lifting completely off, so lift it high enough to clear the plastic parts, then rotate it 180 degrees around and set it on something to support it.
  3. Lift the scanner head until it comes off the guide rod and disengages from the drive belt.
  4. Move the scanner head to the other end of the bed and reingage it onto the belt and guide rod - this is a little tricky to get the belt to pop back into the scanner head, but I got it to go by holding the belt firmly on either side of the head and squeezing both together.
  5. Replace top and all screws, pop control panel cover back into place.
  6. Rejoice in saving yourself lots of $$ and preventing more junk from entering the landfill!
Feb 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
35 people viewed this question
Ben Johnson
