Question about Copystar CS-1500 Copier
Toner cartridge I have a Copystar 1500 copier and want to replace the toner cartridge; however, I can't remove the existing cartridge, because the top cover doesn't NOT open high enough. How do you get that cover to open all the way? RH
    Problem Solver:
  • 20 Answers
While pressing the center of the cover pull out the cover then bring it upward,
Posted on Aug 30, 2009
HOW DO I CHANGE THE TONER
open the top cover just above the multipurpose feeder.
locate the blue lever push it to the right (spring loaded) possible push to the left. that releases the toner cartridge. throw it in the trash and install new toner in reverse order.
Mar 06, 2011 | Copystar CS-1500 Copier
I have an error code C-7 980 on a Copystar 1500. What does that mean?
This is a drum related problem. The waste toner is full. Remove the drum unit, remove toner cartridge and unscrew 2 chrome screws on on the left side of the unit. empty the waste and screw back the screws. replace toner and put back in the machine
Oct 26, 2010 | Copystar CS-1500 Copier
Copystar gs1810 replaced th toner but I can't get
The toner auger is probably clogged up. You will have to disassemble the whole dev unit to clean it out.
Jun 01, 2010 | Copystar CS-1810 Copier
COPYSTAR 1500
the waste tank is full, remove the drum carriage. on bith side remove screw( the one who is inside the hole) dump the waste toner
Jun 22, 2009 | Copystar CS-1500 Copier
Copystar CS-1500 Copier Problem
check the charge corona and discharge corona wire unit either broken wire or the contact no good! one more thing when you replace toner cartridge did you remove the seal?
Dec 09, 2008 | Office Equipment & Supplies
Did you remove the drum unit when fitting the toner? Try reseating it.
Nov 25, 2008 | Copystar CS-1500 Copier
E33 error
E33 means that you've run out of toner. replace the toner cartridge
May 23, 2008 | Copystar CS-1500 Copier
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
Copystar CS-1500 Copier Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
