Question about IBM eserver xSeries 205 8480
IBM xseries 205, Model 8480-43X Memory upgrade an POST BEEP
Hello, I use a IBM server xseries 205, model 8480-43x with momentary 512MB of memory installed. I bought 2gigs of IBM ecc DDR ram (2100, 266Mhz, CL 25. and so on) for my server and installed this memory. when switching on the server, I got a beep like three times three beeps and my server doesnt boot no more. Switching off and on again doesnt solve the problem, even resetting the cmos with 3V-battery removed and the jumper for cmos resetting switched doesnt help.
I have no idea...
  • microwil Apr 21, 2009
    hi! Did you solved yours? Having the same situation here. Tried a 1GB 266MHZ IBM PC2100 ECC CL2.5 DDR ram on it and it deeps 3 times during boot and no more. Which BIOS version your X205 have? I see the latest one on IBM website is v1.53. I haven't check mine yet but I assume it won't be the latest one. I suggest I will try v1.53 to see if that help.
  • Anonymous May 24, 2009
    I had the same problem had to reset or clear my cmos for it to come back up currently I'm trying to put XP on it. Can't find the right SCSI drivers that windows needs.
  • 68 Answers
Those beeps mean that your RAM is not functioning. Are you sure you got the right upgrade type. Sometimes it'll fit into socket but won't work because of speed. Or just try reseating the modules.
Posted on Jan 23, 2009
Ibm xseries 205 reboot after begin the start
Check server has amber on it. If so inspect FAN and replace same if it has amber.
Mar 16, 2013 | IBM eserver xSeries 205 8480
Error three short beeps and three times
Most of the time this is a memory error code. Have you added new memory cards? Sometime the cards are not seated well, are the incorrect placement (cards need to be in pairs)
Check that and post your results. Good Luck.
C2Solutions
Nov 24, 2011 | IBM eServer xSeries x226
I get physical memory dump error while installing windows server 2003
This is a hardware compatibility issue. (Most times) when installing server 2003 and it keeps dumping memory. Check to make sure your system is the correct configuration for the Windows Server 2003.
Good Luck .
C2Solutions
Nov 01, 2011 | IBM eServer xSeries x226
I'm have one server ibm with 1Gb of ram and i want to upgrade but don;t know about it can be support thank for help!
Technology: DDR SDRAM - ECC, max 4Gb, Memory speed: 400MHz, Form factor: DIMM 184-pin, Memory Specification Compliance: PC3200
Jun 30, 2010 | IBM xSeries 206 Server
Do this model supporsts win xp service pack 2
Hi.
This unit has a Pentium 4 2GHz single core processor, and does support Windows XP SP2.
The standard memory installed on this unit was 256KB RAM, in order to run XP efficently you will need to upgrade the RAM. I suggest upgrading RAM to the maximum amount allowed of 2 GB RAM.
To upgrade the RAM to 2 GB you will need 2 modules of 1GB PC2100 184 pin DIMM ECC each.
Micron 1GB DDR RAM PC-2100 ECC
May 25, 2010 | IBM eserver xSeries 205 8480
How to change bios settings, i.e model/type serial number, enable.disable memory banks
Boot the system
Press F1 to enter the Configuration/Setup Utility
Oct 06, 2009 | IBM xSeries 366 Server
What kind of memory for IBM XEON xseries 226 need 4 gigs. help
First, find out exactly what is in it now.
Google "CPUZ"
Download the zip file and extract it.
Run the program and it will provide the exact speed, size and slot locations of your installed memory modules.
Then contact a major memory vendor such as Crucial.com or Kingston.com
Let them know what you have in your server and they will tell you how to get to 4GB.
One more thing, make sure that you have the absolute latest BIOS installed. BIOS updates frequently include support for faster memory. Get the BIOS from IBM's website. You will need the exact model number. It should be on the front of the case by the serial number.
Vote for this solution if it helps.
Aug 17, 2009 | IBM xSeries 226 Server
Ibm eseries 205 8480 lan drivers
This link is for ALL drivers for ALL OS's for that model: xSeries 205 (8480)
Look under the header "Network" and select the appropriate link, depending upon your environment.
Good Luck, and don't forget to rate the results!
Jun 11, 2009 | IBM eserver xSeries 205 8480
IBM eSeries Model 8480-23X Server with Windows 2000 Workstation
how can i setup my 8 pcs(windows 2000) to browse directly on my 2003 server
May 30, 2009 | IBM eserver xSeries 205 8480
IBM eserver xSeries 205 8480 Logo
949 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
