Question about Dryers
GE DBSR 453 EB 2WW won't turn off
I have a GE DBSR 453 EB 2WW dryer. When the time expires the unit continues to run. I see that the control knob doesn't make that final click to turn off the unit. Does the switch need to be changed or can I lube it or what do you suggest? I am pretty handy and can repair but could use some guidance.
aborcass
  • 2651 Answers
SOURCE: MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Posted on Mar 20, 2009
  • 401 Answers
SOURCE: starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Posted on Jan 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: The start knob on my GE Model 453 Dryer is
The timer needs replacement.
Visit Repairclinic.com and type in your full model number, and all the parts available will list.
If you own a phillips screwdriver, you can replace it in under an hour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 05, 2010
localwonder
  • 6784 Answers
SOURCE: Maytag Atlantis Electric Dryer MDE7400AYW Series
HI. This will be a combo issue here. There are two components that work together to provide guidance to the timer during a drying cycle. If both components breakdown, this will induce the symptoms that your are experiencing at this time. The two suspect components will be the Moisture sensor bar assembly and the Chime and dryness board. The moisture bar monitors the humidity in the drum during the cycle. When that humidity level drops, this signal will be sent to the chime/dryness board and then to the timer for advancement guidance. If ant communication between these components are disrupted an any way; The cycle will become unstable and the unit may not stop or it may over dry the clothes.
The necessary actions are to replace the chime/dryness board and the moisture bar assembly. The dryness board will be mounted just behind the rear panel on the top control console. Just remove the rear top panel crews to gain full access. The top console will roll forward once the screws(3) are removed Unscrew the small board from the bracket, and unplug the connectors to replace with the new board. The bar assembly will be mounted on the front lower section of the tumbler assembly. It has two external screws. Once the screws are removed, you can unplug the connector and replace with the new bar.
The part numbers are as follows:
1.Moisture bar:
33001809
2.Chime/dryness board: 33002905
Posted on Aug 17, 2010
SOURCE: MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Posted on Mar 18, 2011
Dryer won't dry clothes
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
The dryer knob won't move while the dryer is on, so it will run for hours and never turn off. What needs to be replaced?
http://forum.appliancepartspros.com/dryer-repair/53816-maytag-dryer-runs-continuously-timer-auto.html
Apr 30, 2011 | GE EED4600GWW Dryer
KNOBS WON T STOP TURNING, THEY WON T START DRYER
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 30, 2010 | GE DRSR483GD Gas Dryer
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
The start knob on my GE Model 453 Dryer is stripped and the metal shaft can't be turned with pliers so I can't start the dryer. Can this be fixed?
Feb 28, 2010 | GE Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
GE Dryer timer stoped working and so it runs and runs
Dryer knob assembly unit is faulty and loss of heat sounds like an element going out.
Dec 10, 2008 | GE DBSR453EBWW Electric Dryer
Electric Dryer Heating problem
Remove the rear vent and run a load on time dry for 45 minutes.
If it dries, repair your exhaust vent.
If not, replace your heating element.
Nov 18, 2008 | GE DBXR453EV Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
