Question about GE Spacemaker JVM1640SJ Microwave Oven
Yam caught fire in microwave
Was cooking yam forgot to check on it - burnt black and on fire inside microwave - now control panel does not work - do i need a new Microwave?
  • david_w_phil Feb 25, 2009
    Potato caught fire in GE Spacemaker Microwave JVM2070SH01 - - I put the potato in, put in on SENSOR mode - and turned to answer an e-mail... I hear a crackling sound a few minutes later to find flames coming out...
    After I extinguished the flames - I found the potato was nearly incinerated!
    It would have been funny if 1)it didn't ruin my microwave; 2) it didn't ruin my dinner and, 3) it didn't create a real risk to my home.
  • 903 Answers
If you have given the microwave enough time to cool off and it still does not work then I would suggest that you would need a new one, as the circuit board may be fried that connects the control panel.
Posted on Jan 15, 2009
My panasonic caught a fire,what should I do other than unplug it
Caught fire how, where? Inside the cooking area??? In the control area behind the timer ???
Jun 16, 2017 | Panasonic Microwave Ovens
Over cooked noodles ,food caught fire, no visible external damage,some smoke black, but control panel dead completely.What can i do ?
Probably the main fuse has blown. If there is damage to the inside of the microwave I would seek professional service to ensure that seals are still working.
May 08, 2015 | Goldstar Microwave Ovens
Put a potato in microwave it caught on fire dish broke no power to the microwave...did I kill it for good or is there a reset button on it...the microwave in build into my cabinets back of microwave is...
When cooking a potato in the microwave Without puncturing it with a fork... it definitively EXPLODS braking the CAROUSSEL PLATEAU and probably damaging some delicate electronics inside, (you have to pearce the potato with a fork to let steem out when cooking) if you are lucky it could be just a blown fuse inside, have it checked by a proffessional (there is normally no reset for a microwave oven exception maiby for the control panel)
Jan 14, 2011 | GE Microwave Ovens
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the...
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Oct 25, 2017 | GE JVM1790 Convection / Microwave Oven
My Frigidaire Microwave caught on fire
The owner's manual warns of the dangers of overcooking potatoes and similar foods and not to ever leave the oven unattended while it's running.
If for some reason you don't have your owner's manual, you can download Frigidaire owner's manuals and installation instructions here.
Are you looking for help to get your microwave working again?
Chances are it's just an opened flame sensor (cavity thermostat / thermal cutout / T.C.O.). Its job is to cut power if there's a fire.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components for testing and possible replacement (like the oven cavity thermostat) will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Jun 07, 2009 | Frigidaire FMT116E1B Microwave Oven
Potato caught fire during cooking. Microwave has
Hello, inside most microwaves, there is a thermal fuse, that if something in the cooking cavity is on fire, it will melt the thermal fuse, if it gets hot enough, thus breaking the power to the unit shutting it off. This sounds like what has happened to yours, simply replacing it will correct the problem. It is usually located near a cavity exhaust point. If you aren't comfortable doing this, as it requires removing the outer cover, while unplugged, and locating/replacing it, take it to a appliance service co. This will of course cost more, if you do it yourself, make sure you provide all of your make/model/serial/anything else, that will identify your unit, and call/go online to a parts retailer, and you should be able to get it done fairly cheap.
Hope this helps, and thank you.
Mar 01, 2009 | Microwave Ovens
My daughter heated a rag in the micro and it caught on fire.
If everything is on, like your display lights and if the bulb lights inside the microwave when you close the door and press start, then you probably damaged the magnetron. The magnetron is the part that emits those high frequency microwaves and cooks the food from the inside out. I do not think there are any other damaged components. The reason I say that is that the magnetron through that little cavity or grille you see on the inside of your microwave was the closest thing to the fire and was damaged directly. By unplugging everything you can take the cover off. The magnetron sits behind the control panel but on top. It has cooling fins and two wires that plug into it. It is possible that one or both of those wires got burned. You will just have to look at it and visually inspect the magnetron. To take it off by unscrewing 4 screws and unplugging the two wire terminals that go to it. If there are no burnt wires going to it then your magnetron was damaged providing as I said above that everything else is normal it just doesn't heat anymore. You can get another one at a local electronics supply house or from www.mwoparts.com. Good luck.
Jan 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I placed yam to microwave - left room and came back to see yam on fire (black as coal) and now my microwave control panel does not work - the yam was on fire before I put it out. filled the house with...
my son did the same with a conker /horsechestnut micowave full of soot kitchen full of smoke microwave was no more / the soot got in to everything just had to replace it
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Decor DMO2420 Microwave caught on fire
Please write back with more details if this reply doesn't solve it.
(Such as, Was the fire inside the cooking cavity? Has the inside been cleaned since?)
There is a cavity temperature fuse located under the outer cover, on the top left side of the cooking cavity. It is rated at 150 degrees centigrade.
If there is a fire, that will open, killing all power to the unit.
A replacement can be found at a local appliance parts company.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 29, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
212 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
