Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 won't boot up
I have a Panasonic TOUGHBOOK CF-18 and when you turn it on you see the intial Panasonic screen and then it goes to a blank screen with a flashing cursor and thats as far as it will go. If you hit F2 while the Panasonic screen is visible you can get into the setup utility but I don't know what to do from there, if anything. Any suggestions about what is wrong?
4 Suggested Answers
SOURCE: CF-18 GPS installation
http://toughbookcentral.com/category/guides
Posted on Jul 10, 2009
  • 3 Answers
SOURCE: Toughbook CF-18 Supervisor Passwd
Toughbook CF18, CF-18
How to remove the BIOS Supervisor Password:
Open all covers and openings. Remove hard drive and battery. Remove bottom of notebook. Many many tiny screws.
Now look towards the rear of the notebook. You will see 2 plugs both have a red and black wires. The one with the much smaller wires and connector is the BIOS battery. Use a pair of needle nose pliers and remove this plug.
Leave it off for 5-15 minutes.
Leave the BIOS battery plug off. Replace the laptop's main battery. Leave the hard drive out. Turn the unit over and turn it on.
Press F2 when the screen comes up. POOF! NO PASSWORD!
Go to Security and disable the password. Save configuration. Turn off the notebook. Replace the small connector. Turn it back over and turn it back on. Press F2 and verify that there is no password. Go to Security and Disable the password again. Save the configuration.
Put the bottom back on. You're done.
NOW FOR THE BAD NEWS!!!
Your hard drive is now dead. Replace it. When a supervisor password is used it locks the hard drive to that password. There is NO WAY to recover the hard drive. It is called an ATA security password. Without the ATA password the hard drive is completely useless.
Posted on Oct 10, 2009
  • 23 Answers
SOURCE: HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Posted on Mar 15, 2010
I need to the Panasonic cf-18 drivers for a sounds, video and gps and touch screen os
Go there :
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
or there :
http://www.panasonic.com/business/toughbook/computer-support-search-downloads.asp
Choose your model, OS, language.
Select Category=All Drivers.
From the list, download and (re-)install the driver and utility related to your device.
Don't forget to comply with the Install Instruction (beginning of the list) :
it indicates the correct drivers installation order.
Jul 13, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
How do i turn my laptop in safe mode
Press power button and press F8 repeatedly until you get the black screen offering option to boot the system into safe mode.
CreativeTECH
Dec 08, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Touch screen
Send me your email address. I have all of the drivers. I ran into this problem, be cause the tablet drivers from panasonic would not work. I downloaded a driver direct from WACOM and it solved the problem.
Dec 01, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
992 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
ddalecki
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
