Question about Fujitsu LIFEBOOK E4010 PC Notebook
Won't switch on
Sometimes it will sometimes it won't switch on The note book will not power up when you depress start button. Battery is good, and AC power cord is connected. Cooling fan comes on momentarily, but shuts off when you release start button.
Latop will not boot up
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power
indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your
screen when your lid is open or closed respectively. Normally the operator does not push this button.
These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often
they will require replacements. If you aren't an expert repair person, get a technician to
repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to
repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies
elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will
require professional help.
Nov 02, 2012 | Dell Inspiron 1526 Notebook
I have the Sony S2 Sports ZS X1 and it will not turn on.
Before confirm transformer fault, load batteries and see whether it works. After loading batteries, pull out its AC cord from its AC socket at it back side. With AC cord connected at the back of the set, battery supply won't connected to the set. There is a cut - off switch at the AC socket. Only after removing the AC cord, the set will work on battery.
Try this. If it works with battery, make sure that transformer or internal mains fuse has blown out.
May 29, 2012 | Sony S2 Sports ZS-X1 Radio/CD Boombox
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
Nov 12, 2009 | Dell Latitude D800 Notebook
Not turning on
take the batt out the sys. then put the charger. wait 3 min after that turn your sys on.
without the batt. if it turn on. your batt is damaged. if it dont turn on without the batt and
just the power cord is there. then your power suply node is broken or just no good.
if the sys goes on wait 11 min must 11 min exact. them put the batt on it and take the
power cord off. if sys stays on. your ok.
Dec 30, 2008 | HP Compaq NC6400 Business Notebook
Fujitsu LIFEBOOK E4010 PC Notebook Logo
166 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
