Question about Advueu Technology ADV178T 17" Flat Panel LCD Monitor
Monitor : no display and blue led light is blinking
I have an amw monitor 17" LCD screen. I have notice for past few days , it would take a good minute and half to load the display on the screen, but after that it would work perfectly. But today, i had shutdown my pc for while and turn off my screen. 6 hours later, when i turn it on, the screen wouldn't display anything and blue led light (power light) is blinking constantly. I can hear some light noise from the screen, but it will not display anything. I have done some research on this, i found out that it might has to do with capacitors on the power supply or inverter board ?? BUt i don't know where the power supply is or the inverter board .. Please help me, i really appericate your help in advance. Thank you for reading
  • sick421 Jan 17, 2009
    Well, it is the monitor, cuz i'm using a different monitor on my computer and it works.
  • HikerTracy Feb 24, 2009
    I have the same problem with my AMW A912WDB 19". However, now I don't even get a blinking blue light... I get nothing. Swapped out the monitors to be sure it wasn't a video card problem (other monitor worked fine). Called Promedialcd tech support because I thought the monitor had a 3 yr warrenty. It does not, only 1 year. Any suggestions beyong the recycling bin?
  • 2,692 Answers
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Posted on Jan 14, 2009
AMW LCD Monitor Display Model A913B
Try separating the wiring. Touching wires can cause cross-talk of signals. Separating wires stopped my "shadows" on my screen.
Feb 10, 2014 | Computers & Internet
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Why our HP L1740 17" LCD monitor has no display at all but had power
Good Day sir/maam, lets try to make sure that the LCD is the problem and not the CPU,
  1. Swap your LCD to a good CPU, to check if the LCD is good (visit a friend who has a PC).
  2. Or as you boot your PC, did you hear a single beep? and
  3. Does your PC hard disk led blinks.
If you insist that the LCD is the problem, you may need to check first your dealer for advice.
Oct 20, 2009 | HP L1740 17" LCD Monitor
Screen turns black and blue LED is blinking
Sounds like the monitor is being made to show a resolution it does not support. Check the available resolutions the monitor supports and then check what resolution the video card is giving, if it not compatable, you get the black and blue screens.
For the video card, right click on the desktop in a an empty area and choose properties > settings > your resolution from the card will be there. Now from there click on advanced > click on monitor and look at the monitor settings. Make sure the box is checked to hide modes the monitor cannot display. Now click on the adapter tab and click below on all modes. This is the list of all modes that both the monitor and the video card argree on. Make sure the settings in your game match one of these and you should be good to go.
Sep 14, 2009 | LG Studioworks 563N 15" CRT Monitor
Amw monitor blinks with a blue power light
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Jul 11, 2009 | Advueu Technology AMW-F176B Monitor
One monitor clear the other not good fonts
I installed a better video card that supported dual monitors without splitting the signal.
Nov 19, 2008 | Advueu Technology ADV178T 17" Flat Panel...
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
Blinking Blue Power Led on front, Monitor is non-responsive
Hallo.Sorry for me english first.I have question.You plugg in a monitor with a notebok,or dektop pc? If you conect monitor with a notebook, i thing, you must change a display settings.This is very easy.On the ntb keyboar press and hold Fn-key and at same time press f4 key,and you cann chage the output canal for video signal,Lcd in notebook,external LCd or Both. I hope, it will help for you. Bye Perdo
Jul 27, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Advueu Technology ADV178T 17" Flat Panel LCD Monitor Logo
459 people viewed this question
Top Advueu Technology Computers & Internet Experts
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
