Question about Kenmore Elite 45986 Front Load Washer
98 ford taurus
Why won't it start?
  • jer1443 May 11, 2010
    need more info
  • 15,935 Answers
Because you don't have an ignition in the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Where's VSS located?
Fixing Ford Taurus Shift Problem. Replacing VSS Vehicle ...
? 7:17
www.youtube.com/watch?v=y0823ZDqxiU
Aug 12, 2010 - Uploaded by Larry W Changing the VSS on a 99 Ford Taurus 3.0L Duratec 24Valve DOHC engine. Symptoms: ... Replacing VSS Vehicle Speed Sensor. Larry W.
98 ford Taurus VSS (vehicle speed sensor) - YouTube
? 1:42
https://www.youtube.com/watch?v=OoPKhl2p6ao
Mar 14, 2015 - Uploaded by Sharon Kay
Location of VSS and how to get to it on a 98 Ford Taurus. Disregard the yr i give in the video. I have 2 other ...
Nov 03, 2015 | 1996 Ford Taurus
I have a 98 Chevy Malibu Ls and the ignition won't
Inspect the old ignition cycle which is out.Is there any problem noticed of Ignition cylinder getting worn out.
Because when issue of ignition not turning off,its faulty ignition lock cylinder or faulty ignition switch.I suggest re-inspect the new ignition cylinder.
For more help,click the help link mentioned below:----
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
I have a 2000 Ford Taurus. My wife left the radio running with the ignition off for a short while. Now the car won't turn over, won't start, won't jump. There is one click when trying to s
The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
Sep 22, 2012 | 2000 Ford Taurus
2002 ford taurus won't start - brand new battery and complete tune up still won't start
Sounds like your not getting any fuel..Listen for the fuel pump,by removing gas cap and put your ear up to it..cycle the key without starting it and listen for the pump..sometimes you can beat on the bottom of the tank and it will jarr the pump and it will start running again..Not a fix but a conformation
Sep 08, 2011 | 2002 Ford Taurus
Have a 98 Ford Taurus was driving fine then inside of car started filling up with smoke and overheated, then engine died. Now it won't start. Checked fluid levels. They are fine. What should I look for...
We have no idea if you have any knowledge about motor
vehicles at all
So to go into all sorts of diagnostic & testing approaches,
only for you to tell us you never work on your own vehicles,
won't do much for you
It sounds as though your engine is in serious trouble
& may not be fixable in the car as is
Need a lot more to go on to give any ideas
Aug 02, 2011 | Ford Taurus Cars & Trucks
Put in new alternator 98 ford taurus dohc car will start thn stop
Check ground wire from engine to frame and battery to body
Jul 23, 2010 | 1998 Ford Taurus
Can a 91 ford taurus 3.6 be swapped out with a 98
there would be more time and work involved with replacing wiring and ecu. i would never attemp.
Mar 22, 2010 | 1991 Ford Taurus
Battery grounding problem for ford taurus 98
Either the ground cable is loose or corroded at block connection . If cleaning this does not help, change the cable!
Mar 14, 2009 | 1998 Ford Taurus
Kenmore Elite 45986 Front Load Washer Logo
29 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
