Question about Mitsubishi WS-55809 55" Rear Projection Television
WS-B55. HDTV Receiver. Suggestions
Wish to install HDTV receiver for this TV set. Recommendation?
Have to call DTV and find out if it is worth it. My rear projection TV was built in August 2002. It works very well and with the "digital" image that comes with the provider reception is very good.
Posted on Jan 15, 2009
How do ihook up a digital antenna to my tv
Dominic, you do not state whether you want large outdoor antenna or simple indoor.
If you bought your HDTV anytime during the past 8 years or so, it should have a built-in tuner for receiving digital over-the-air broadcasts. If you have an older "HDTV-ready" TV that only receives analog signals, you'll need to connect it to a separate HDTV tuner.
link below tells how to install outdoor digital TV antenna.
press the helpful button.
How to Install Digital TV Antenna Digital TV Help
Jan 19, 2016 | Televison & Video
Polaroid lcd HDTV FLM-323B can not receive stations with external indoor antenna
INDOOR ARIEL MAY BE TO WEAK LO FOR TV APLIFIER ARIEL ON EBAY OR GET OUTSIDE ONE FITTED
Sep 28, 2017 | Polaroid FLM-323B Television
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Windows media center can not find ir receiver
be sure you have installed the driver. If you are using windows 7 you still need to install the winTV driver. I know this because I had the same problem. It should work then. Just go to TV setting in the media center setup and it should scan for channels.
Jul 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Installing a receiver
plug the receiver directly to the tv first without the panasonic. set up the receiver . then add the panasonic. the panasonic probably doesnt have a digital tuner so use composite av cables (yellow, red, white) from the reciever to the player
Dec 30, 2008 | Samsung HDTV Digital Terrestrial Receiver
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Nov 20, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Screen calibration
want to get the best picture possible out of my Philips 42PFL3603D HDTV. Any recommendation on screen settings or software to help with this?
May 26, 2008 | Televison & Video
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
