Question about Dyson DC25 All Floors Bagless Upright Vacuum
Roller not turning - dyson DC25
I got the belt of a robe caught in it and pulled it out - i am thinking that caused the situation - could that be correct? and what can i do?
  • 4 more comments
  • Anonymous Jan 27, 2009
    same scenario here - left with a crackin hoover that wont do its proper job
  • cdbees Mar 14, 2009
    I vacuumed over the end of a spool of thread, winding the thread on the roller and now the roller will not turn. I removed all of the thread but I'm afraid the belt is shot. How do I replace it?
  • Bluebird33 May 17, 2009
    Don't Dyson read this????? What is the solution. Mine was with a shoelace and now won't turn/pick up.
  • Anonymous May 24, 2009
    I ran over a string and now the beater bar won't run. It turns manually, there is nothing visably wrong with this. Isn't there a reset button on th beater bar motor?
  • 2summergem
    2summergem Oct 31, 2012
    Of course as much as I try to remember to clean the strings and stuff that ends up wound around the brush on a routine basis, I found that the same was there and cleaned it all but the brush still would not spin. Pushing that button next to the power button fixed it. I'm overjoyed that this one time I did not have to spend a ton of money fixing it. Thanks
  • Anonymous Mar 15, 2014
    the ball is not moving properly
I had the same problem. I found that pushing the button next to the power button fixed it.
Posted on Jun 12, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Check the neck if a large object is stuck in it
Posted on Jan 15, 2009
This is the 2nd time this happened. The first time I replaced the roller head at a cost of 80 quid!!! I definately prefer this fix !!!!!!!
Posted on Mar 13, 2011
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Drag sound on floors when using dyson dc25
    Hi there, it's Jack at Dyson.
    DC25 is engineered to work effectively on hard floors as well as on carpets. It shouldn't be making an unusual noise on floors - it would be worth checking the soleplate (the underside of the cleaner head) for any damage, and for any debris caught underneath. It's also a good idea to make sure all the rollers turn freely.
    If you can't see any obvious issues but continue to experience difficulty, please contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts can provide further assistance to help you resolve things.
    Sep 24, 2014 | Dyson DC25 All Floors Bagless Upright...
    I just bought a new beater brush for my dc25 dyson and it still does not work any ideas
    Hi, it's Allie from Crucial Vacuum.
    When installing your new Dyson DC25 roller brush, make sure that once installed, you incline your unit into the vacuuming position by using the stabilizer. The roller brush will only turn while in this position. Also, make sure that your roller brush is properly installed and the end cap holder is properly placed back into the unit.
    Below you may find a video tutorial on how to replace your roller brush:
    https://www.youtube.com/watch?v=juf7zdvChUc
    You can purchase direct your replacement belts, roller brush and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    http://www.crucialvacuum.com/catalogsearch/result/?q=DC25
    I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
    Alejandra (Allie) Sepulveda-Rivera
    Crucial Vacuum Customer Care
    Sep 14, 2014 | Dyson Vacuums
    Why won't the brush head on my DC25 turn?
    If the brush bar motor isn't turning it could be the switch or the motor, if it is turning you may need. To replace the belt
    Aug 02, 2014 | Dyson DC25 Animal Upright Ball Bagless...
    Dyson dc 25 animal brush not rotating
    Hello, this is Ava with Think Crucial.
    There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
    First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
    While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
    You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    https://www.thinkcrucial.com/search?type=product&q=dyson
    Ava B.
    Think Crucial Customer Care
    http://www.thinkcrucial.com/
    Apr 12, 2012 | Dyson DC25 All Floors Bagless Upright...
    I have a dyson roller ball vacuum cleaner DC25. The brush will not turn when I am running the machine. It turns manually' Wally from San Antonio
    Ava B.
    Jan 29, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Non working roller brush on dyson dc25 vacuum cleaner
    There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    Ava B.
    Jun 08, 2010 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC25 All Floors Bagless Upright Vacuum Logo
    2,852 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
