Question about Maxtor MaXLine 3 250 GB Hard Drive
IT LOOKS DEAD
I'm building a computer. I get no response from this Maxtor Maxline III SATA150 250GB HDD. I've hooked up the SATA cable and the power cable. There are another 4 pins on the back of the hard drive that have nothing plugged in. Is this a problem?
  • 74 Answers
Need some more information to help you. Does your drive even spin up? If not, are the extra 4 pins you are referring to similar to the standard power pins on the PATA drives? If so they are to be used with power supplies that do not have the SATA power connector. You can use EITHER the SATA power connector(15 pin) OR the other 4 pin power connector. NOT BOTH !!! If the pins are not power connectors, then you are probably referring to jumper pins. Ensure that that all the jumper pins are open. If the drive still does not spin up, the pin 11 on the SATA power cable is probably floating indicating a delayed spin up mode. In this mode, the drive will need the PHY initialization sequence from the system before spinning up. You can override this by grounding pin 11 of the 15 pin SATA power connector. Refer to the attached picture for clarification. If you still have questions send me a comment.
Posted on Jun 16, 2007
11S09N0848ZJ1BLDP019YA
what problem, it is not shinny any more? LOL?
do say. please.
I am clueless, so far due to?
what system? PC, MAC,DVR,ext, TV, moon rocket.(LOL)
what OS?
using it as an internal drive, 2nd drive, or external.?
boot drive?
Seagate bought out MAXTOR.
that number must be a bar code, its not the product number
eg:
so tell me what it is.
as time passes, maxtor, fades to dark at SeaGate.
but this deep search nets, this, (hidden well)
http://www.seagate.com/gb/en/search/?keyword=maxtor
ive been using MAXTOR since day 1.
decodes for Maxtor :
Maxtor
xayb0
xa = drive family
- 6Y = DiamondMax(DM) Plus 9
- 6B = DM10
- 6L = DM10 RoHS compliant version
- 6H = DM11
- 7B = MaxLine(ML)III
- 7L = MLIII RoHS compliant
- 7H = ML Pro
- 4R = DM16
- 2F = Fireball 3
- 6E = DM Plus 8
- 5A = ML II
- 7Y = ML Plus II
y = the capacity of the disk, in gigabytes. Drives less than 100GB will have a leading zero (80GB is denoted as 080, etc)
b = buffer size and interface
- J = 2MB PATA with ball-bearing motor
- L = 2MB PATA with fluid dynamic bearing (FDB) motor
- P = 8MB PATA
- R = 16MB PATA
- M = 8MB SATA
- S = 16MB SATA
- F = 16MB SATA 3gbps
All Maxtor SKUs have a zero at the end. It may have a value, but I'm not aware of one.
Example: A Maxtor drive with a model number of 6Y200P0 is a 200GB 7200RPM PATA drive with an 8MB buffer from the DiamondMax Plus 9 family.
now my generic answer: for all HDD. A+ training....(instructor)
1: i make sure it has +5v and 12vdc power, if not all is hopeless.
2: IF PATA/SATA , i listen to the drive case with my ear.
whirrrrrrrrrrrrrr, no whirrrrrrr ,? its DOA.
if it spins its good. if not its 100% DEAD, (RIP)
3: do the gyro test, (if it fights you, as you change it's direction, then it is spinning) Drive in HAND. (whole deal)
4: does BIOS see it? (MOBO BIOS) hot key hit. RTM on MOBO.
yes, good.
no , DEAD. try another power cord to drive or data cable.
try different data ports. on MOBO.
5: try it on 1 PC, with step 4 and 5
6: if BIOS sees it ,so should WINDOWS. (may)
in the device manager.
and in disk manager. (off computer management CPL)
both. set the drive latter in the latter or it will be hidden.
keep in mind BIOS never tests a drive. it only asks it for
its NAME (PNP) PNP just identiifes the maker and type drive. and its spec. and 1 more tests. it shows the drive is NOT BUSY.
these facts ,help all techs, make good trouble shooting.
Sep 24, 2013 | Maxtor Hard Drive
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
I have a Toshiba Tecra A-6EZ6312 and I can't get it to load up. When it is starting up it goes to a screen that says Intel (R) Boot Agent GE v.1.2.30 Copyright (C) 1997-2005, Intel Corporation CLIENT...
You neglected to mention if it has booted up in the past but considering the age of your computer, I'm assuming that it has.
More than likely your hard drive (HDD) has failed and you'll need to replace it and reinstall XP. The only other option really would be that you've got bad connections or that the interface between the hard drive and the HDD has failed. That's unlikely though because you wouldn't get a message about no OS being installed, you'd get a message about not having a HDD installed because your computer can't see it. A computer can still see a HDD even if its failed providing that it can still receive power and communicate with the motherboard. Before you do anything, though, pull the HDD with the power off on the laptop (one or two screws at the most) and battery and power supply disconnected. Then, power up the computer without the HDD. The System BIOS should recognize that there is no HDD installed and yell at you for it. Power down the computer, disconnect the power supply and the battery again and reinstall the HDD. Then power up the computer. That may solve the problem. If not, keep reading because we're going to need to test it before we make any decisions.
To confirm that it is a dead hard drive, you'll need to test it on another computer, preferably a desktop as it will be the easiest to do and hopefully won't require you to spend any money other than on a SATA cable (unless you already have one) just to test it. I've looked up the technical specs on your laptop and it came standard with an 80 GB SATA 2.5" HDD. Assuming that your using the same hard drive that came with the laptop, and your desktop has a SATA interface and power as well, you'll first need to disconnect the hard drive from your laptop . Now, if your desktop doesn't support SATA or you're using a second laptop to perform the test, stop right here and advance to the second section that covers performing the test on non-SATA desktops and second laptops.
SATA Signal Cable: captainhawk1_5.jpg
SATA Power Cable:
captainhawk1_6.jpg Connecting to a Desktop Computer that supports SATA Interface For the Purpose of the HDD Test:
The easiest way to tell if the computer supports SATA interface HDD is by looking at the HDD currently installed on the desktop. I always use non-conductive (latex, neoprene) gloves when I work inside of a computer to prevent static discharges that can destroy your computer. You should too.
Turn off the desktop, and disconnect power. Open the case. If the connections for that HDD are SATA, the cables that are connected to it will look like the examples above. If they don't, your computer does not support SATA so you'll need to stop and go on to the next section.
Now, you'll need a SATA signal cable (if you don't already have an extra one). You can get a SATA signal cable at any electronics or computer retailer. It shouldn't cost you more than $5.00. Next connect one end of it to the laptop HDD and the other end to the connection on the motherboard that will most likely be right next to where the SATA signal cable for the primary HDD is already connected to.
You shouldn't need to purchase a SATA power cable (indicated in the second picture) or a SATA to Molex adapter cable because your power supply should have at least one or two extra SATA connectors attached to it. If by some chance it doesn't, you'll need to purchase a MOLEX to SATA adapter cable (see the image below) and connect it to one of the several Molex connectors attached to the power supply (labeled with a "P" and a number. Example: P7). Again, this adapter should be easily acquired at any electronics/computer retailer and should be no more than $5.00 Now, connect the SATA power cable (or adapted cable) to the laptop HDD. You're now ready to do the test. Keep the case open when performing the test to monitor the laptop HDD and because, well... it's a heck of a lot easier than constantly opening and closing the thing and considering you'll have an HDD in there that's not mounted to anything, it's the safer bet. Skip the next section on connecting using a desktop computer that does not support SATA and go directly to the section on performing the test.
MOLEX to SATA Power Adapter Cable (may have multiple SATA connectors as well): captainhawk1_7.jpg
Connecting to a Desktop COmputer that Does Not Support SATA Interface (Supports IDE) or Connecting to Another Laptop For the Purpose of the HDD Test:
If the desktop computer you are using to perform the laptop HDD test does not support the SATA Interface or if you are using another laptop computer to perform the test, you are going to have to connect the laptop to the computer via USB interface. To accomplish this you will need a 2.5" Hard Drive Enclosure. A hard drive enclosure converts an internal hard drive into an external hard drive. They cost between $5 and $25 and you'll get a better deal online. Following the directions for the enclosure, connect your laptop HDD to your test computer. You should be able to easily tell if the drive is spinning up and the LED's on the enclosure should be flashing just like they do on a computer when a HDD is being accessed.
Performing the Test:
This is the easiest part of the whole show. If you haven't done it already, reconnect the power cable to the test computer and power it on. Go to My Computer on the desktop of the test computer (Computer if running Vista or Win7), double-click on it and a window will open. Once you find the laptop drive, double click on it and start searching around and see what you've got. If you don't see the drive, we've confirmed that the HDD has failed. If you do see the drive but open it up and there's either nothing on it or you get error messages when you attempt to access the folders, the hard drive has failed as well. In either case, you will certainly need to replace the HDD as I suggested in the beginning however, your data may still be retrievable. You'll need to get it to a local computer repair shop and get a quote.
On the other hand, if you can open up the files and access all of them, your HDD has not failed but, you have a very damaged Windows installation. This also may be reparable, but again, you'll need to get it to a professional to fix it. Before you do that, though, make sure to copy all of your important documents, photos, videos, etc., to the test computer's hard drive or onto the removable media (SD Card, Flash Drive, etc.) connected to the test computer.
Apr 28, 2011 | Toshiba TECRA A6-EZ6312 (PTA60U05T00F) PC...
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
I am looking for a user guide for a Black Armor 320 GB Maxtor, ¿can you help?
why would you need one ? Maxtor has a jumper label
on their face that is all the info you'll need to operate
this HDD , the rest is in the OS set up NTFS or
FAT32 , stick with the NTFS and you'll have no
problems , the jumper label indicates using as a
master , Slave or a Cable select , the IDE cable
in your computer if using an ATA HDD has two
connections the top one is the master the lower
one is the slave , if the HDD is a SATA it has its
own special connection which is marked SATA
Jan 19, 2010 | Maxtor Hard Drive
DRIVE MAKES CLICKING SOUNDS AND EVENTUALLY CAUSES SYSTEM TO CRASH
The only thing you can do is replace the drive. You might be able to burn some data to a CD or DVD or external hard drive before the replacement, but it cannot be guaranteed.
Nov 18, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Maxtor MaXLine 3 250 GB Hard Drive Logo
177 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
