Konica Minolta KONICA BR BIZHUB C451 1BLACK IMAGING UNIT Logo
A
Anonymous Posted on Dec 17, 2012
First page of PDF files is printed in 10% size - rest of document is ok
When I print a PDF file from Adobe Reader 9 to a Konica Minolta KONICA BR BIZHUB C451 network printer the first page comes out in 10% size - the rest of the document is ok. All settings in the printer setup has been reset.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 02, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913832
Points
11960
Sir/Mam,
Does this happen with a word file, or a web page, or outlook, excel
please check. if OK with them its the file its bad. Mite want to upgrade the adobe to 10 or 11 current. Try different computer also. Print different adobe files also.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2 Related Answers
Anonymous
  • 62 Answers
  • Posted on Feb 25, 2011
SOURCE: konica minolta Bizhub C350. Following message
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Ty Schmidt
  • 118 Answers
  • Posted on Nov 10, 2011
SOURCE: i have problerm with konica minolta c353 .. the
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
I cant print from my computer to konica minolta bizhub c250
are you the only person connected to the machine can others? try different file pdf, web page, document email
Bizhub 284e not printing
does it copy Ok does it print out the demo page ok does it print out the meter count page ok does print other types of files web page ,pdf etc.
Only blank pages printed out of Oracle
does the machine print ok with word, web papge pdf, etc if so its the oracle issue, or just the oracle file try other files?
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
2answers
Document size and page size when printing
Its not a setting for page size, that must always be set to the paper size. The best way is to remove the margins in the document by editing it in a PDF editor. Alternatives are a bit of a bodge. When you print try changing the size to 115% of original.
CHEQUE PRINTING CONFIGURATION IN CANON LBP3300
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size or page setup when printing from an application, taking Adobe Reader 6.0 as an example.
Note: The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note: The printer name displayed in this dialog box can be changed in the [Printers and Faxes] folder (the [Printers] folder for Windows 98/Me/2000).
3helpful
Printing PDF files from Mac to a Konica Minolta 750 with an IC202 controller. they are taking forever to print. Any solutions?
Adobe has had this type of problem, and they do not acknowledge it. Best answer is to hook printer up directly to the computer, printing over a network, takes forever, and often errors. The issue is Adobe.
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
When clicking on Printing Preferences, the display is not in English... How do I change this?
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Konica-Minolta-PagePro-1400-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
1helpful
PRINTING WINGDINGS WHEN I PRINT PDF FILES
Adobe PDF reader tends to print webdings/wingdings in its version 8 incarnation. Download FOXIT reader free from filehippo.com and try to print your document from that instead of Adobe. This nearly always fixes the problem. antosarmy
My Konica Minolta magicolour 2500w won't print web pages any more
I believe it is a Windows problem and not a printer problem. Try to print from a different application, to see if it is working.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
