Question about Nikon FA 35mm SLR Camera
Nikon FA will not advance. Meter will not give reading.
Nikon FA advance lever will not advance. Meter will not give reading. Fresh batteries installed. Meter only flashes "+F32" when turning the aperture dial on lens. Camera works fine on M and bulb settings.
Nikon Fa advance lever loose.
Not used camera for a few years and set to M250 mode due to not having batteries, Advanced lever once to test, advanced one, then pulled lever back for another test.
Lever then feels lifeless and has no resistance to being moved. it will not take a picture even with batteries. any Idea what the problem is?
Posted on Dec 10, 2009
    Problem Solver:
  • 17 Answers
The capacitor is bad or the circut has a fault somewhere. You will need to take it to a camera tech or just use it in the manual moide only
Posted on Mar 07, 2009
Nikon fa advance level fell off
I can tell you that you can't fix it yourself
Mar 07, 2013 | Nikon FA 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
My FA camera shutter release button won't work, no reaction when depressed and look through the view finder was dark.
The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two SR44's or LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
Feb 18, 2011 | Nikon FA 35mm SLR Camera
Nikon FA depth of field preview lever sticky
The small lever on the inside of the mirror box is what controls the aperture. If the lever on the outside is sticking, it would only hold the lever on the inside down so you would be stopped down all the time. You can try a small amount of lighter fluid at the base of the outside lever and work it back and forth to see if it would free up.
Jan 19, 2010 | Nikon FA 35mm SLR Camera
My Nikon FE film advance lever is stuck. It does not move at all, there is no film in the camera. The repair shop wants $100 to fix it which is more than the camera is worth I think. I would like to do...
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
Dec 12, 2009 | Nikon Photography
Nikon Fa advance lever loose. Not used camera for a few years and set to M250 mode due to not having batteries, Advanced lever once to test, advanced one, then pulled lever back for another test. Lever...
Try moving the coupler on the bottom where the motor drive would connect. See if you can rotate the piece clockwise. With the advance lever loose, it may be in mid-cycle on the winding/advance
Dec 10, 2009 | Nikon FA 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Can't Find Battery.
The camera itself doesn't have a battery. If you have a light meter in the finder however, then the battery for it is in the finder itself. Press the button the back on the left side while at the same time, push the lever over on the finder. That will release the viewfinder.
Look underneath and you will see the battery cap. Unscrew that and you'll see the compartment. If it is an old FTn finder, then it will likely take the mercury batteries that are about 1.35V. They don't sell those anymore as mercury is illegal in consumer batteries, but if you do a search on eBay for 1.35V WEIN cells you should be able to track down replacement batteries.
You could put Duracell PX625 batteries in, but they ar 1.5V and thus will give inaccurate meter readings.
Dec 29, 2008 | Nikon Cameras
Shutter remains open
It may be fatal as there are no parts available for the FE series. The main components that cause this problem are the FRE/ASA unit and the meter itself. The FRE is located under the rewind knob side of the top cover. It is made of glass and can be damaged by impact. The meter is under the speed dial and can also cause this type of problem. Neither is a easy repair.
Nov 25, 2007 | Nikon FE 35mm SLR Camera
Nikon FA 35mm SLR Camera Logo
343 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
