Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Screen color/picture quality
We were given the 60PP920217F but we don't have the original remote, the screen picture/color isn't that good. What is best way to get picture/color looking good?? we have a universal but it won't pull up the menu...
  • jacksonteres Jan 22, 2009
    i have dubble picture and lines and red and green color and showing a half a picture and i dont have the remote that came wiht it. can i order the right one? what can i do to fix this problem?
You can access the menu by hitting two buttons on the TV itself at the same time. You then adjust by hitting the up/down buttons.
The double pictures u mention sounds like a convergence problem.
If adjusting the convergence via the menu does not work
you would need to order 2 parts and be able to solder. A rather inexpensive repair if you can do it yourself.
For step by step info on how to repair click below
Good Luck,
Paula
http://techghetto.com/tv-repair/
Posted on Feb 15, 2009
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
How can open service meno of 14" TV Topdom panasonic
use remote control if front switches are not working if you don't have it then buy a universal remote and go to system menu and try to adjust brightness, colors,and sharpness if that's what you think is the problem
Aug 26, 2012 | Televison & Video
The picture is almost like it is out of convergence it gets better when brite and contrast is turned down
Good day sir John!!!!
That problem is usually cause of bad T-con board (T-con board is the one that responsible for the quality of picture) in normal bright and contrast you see the color/picture is distorted..The color is like over tint and the quality is not good..
However,there are some points to consider like wrong settings and weak/bad connections of digital cable..
Try this steps:
For wrong settings-to determine if you have a wrong settings or you press wrong buttons on remote..Try to go to menu and find default settings or factory settings then press enter to restore factory settings in this procedure all previous settings return to original so the tv is works fine after this if your problem is in the settings..
For digital cable fault- You can determine the problem by playing DVD movies on your TV if the works fine in DVD movies.Your TV is good but there something wrong with the connections of your digital cable please let me know!!..Or you can try to wiggle the coaxial cable on the rear side of your TV and look at the TV screen while you do that and see if there is any improvement or reaction of color/picture try to fix the coaxial wire...
If the above procedure not worked the problem is on T-CON board let me know first if you decided to replace it for proper instruction on how to replace to avoid damage and for your safety..
Just keep on touch sir!!!!
Thanks for choosing my service..
Hope it helps.
Bonifacio
Jan 25, 2012 | Dynex DX40 LCD TV
Some buttons on my remote for my yamaha htr 5750 amp don't work. It's the original and was given to me. The volume and power buttons don't work or make the red lite flash; however the other...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 10, 2011 | Yamaha HTR-5750 Receiver
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 14, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F big screen TV
does anyone know why the picture does not come on .Is there any fuses that might of gone bad?If you know respond to this ?thanks
May 15, 2008 | Televison & Video
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
