Question about Dewalt Saws
Replacement of power cord on a Dewalt 708 type 3 slide mitre
My power cord shorted out right at the end of the slide tube, how tough is it to replace myself ?
  • 2,176 Answers
Not that bad, I would go to Dewaltservicenet.com and look at an explosion before taking yours part. You have to remove the top of the handle, there is cover on the side towards the blade that is tight to remove and then the strain relief on the tube. The cord set that you need is 330078-98 list for 16.76. It is a 10ft 16-2 wire. Just take your time and if you are handy with tools you should have no problem. Let me know if I can help I work on them all the time.
Posted on Jan 15, 2009
I replaced switch and still doesn't work
Check your cord & insure you have continuity to & through the switch first.
Second, check the brushes - make sure they are not worn down & that they slide easily down the brush tube to contact the armature. I have had a few of these with bad field windings - the winding breaks off right at the field connector (you will need a meter to test this)
Aug 10, 2014 | Dewalt Dw718 12" Dual Bevel Sliding...
How should I reconnect the wiring on the switch on this DeWalt mitre saw model no. DW705. Type 7. Model no. 50813 ?
i think the black from the cord goes to 1a
the black to the motor goes to 1 b
the red goes to 2a
the yellow goes to 2b
Jan 06, 2013 | Vacuums
Puppy chewed the cord. It is an internal cord and does not plug into the back of the tv. Can I replace it myself? Directions or diagram? Where is the best place to get the replacement cord?
Any polarized power cord will work----cautions: the cord where it connects inside will have either a white stripe on one side or a rough surface---that is the neutral side---replacement must be soldered to correct points---you get it backwards and set will work but shock hazard will exist-------if you have enough cord left you can do a splice repair-----I cut them back and offset so not next to each other(the two sides of the cord----get some heat shrink tubing--slide it over each side and down a ways---solder the two ends for each side back together (you will lose a little of the cord) and once soldered slide the shrink tubing down over the soldered parts and heat it with a hair dryer and it will shrink air tight over the solder connection's---you do not want the splices side by side to prevent any possible short----for extra protection once done use some black electrical tape and tape the whole area.
Either replace entire cord or splice repair it. Examine cord end to end for any bare wire showing---if chewed in more than one spot replace entire cord.
Nov 08, 2012 | Philips 32PFL3505D 32 in LCD TV
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
My mitre saw won't power up. I moved it and it worked a few days ago. I have it plugged in. The electrical plug has power (checked with something else) but the saw won't turn on. Is there a reset...
There may be a RED reset button on the motor, It won't push very far, Unplug the saw push the reset and try it again
You may have sustained some damage to the power cord and need to take a look at the internal cord connections
Apr 02, 2010 | Dewalt DW712 8 - 1/2" Sliding Compound...
Hi my dewalt 708 lx sliding mitre saw, 110v, seems to only have half the power(speed) that it should have, and cannot cut timber on a compound cut because of this, any suggestions please.
I have heard complaints that this saw does not do well on angled cuts because of its low power. Try running a shorter and/or thicker extension cord and checking your input voltage. That's about all I can think of, hope it helps.
Mar 12, 2010 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Why when i cut a bit of 6" skirting board it does'nt cut square on a brand new ryobi ems 2026 sliding mitre saw
Don't ever assume that the markings on the angle setting are correct and accurate. Always check squareness with a square before you use a miter saw. With almost all brands of power tools being built overseas nowadays there is unfortunately a question of accuracy on most brands. Always check.
Mar 16, 2009 | Dewalt Mitre Saw Workstation
Saws Logo
204 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
