Question about HP PSC 1610 All-In-One InkJet Printer
Copying a Document
When I copy a document (selecting black or color) most of the copy comes out all black with grey lines and no color.
  • 3 Answers
Thanks! I had the same problem with my daughter's printer. She hadn't used the color cartridge in a long time, and it felt too heavy to be empty. About 30 seconds under warm water and all is good!
Posted on Aug 18, 2007
  • 59 Answers
That sounds like a either a dry cartridge or an electronic failure in the cartridge. I would say replace the cartridge first. Try to take the cartridge out, and wipe it with a damp paper towel. If you see a lot of ink, run it under the sink w/ warm water for a minute. But really, I'd say replace it!
Posted on Jun 15, 2007
SOURCE:
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
I am trying to photocopy some pages of a document in black and white, but the copies come out as colored. what can I do in order to copy only black and white document?
A copy is a copy. you get what it sees.
I think you may be successful in scanning the picture to your hard drive, then print it in grey scale.
Feb 23, 2011 | Office Equipment & Supplies
I have a MX4101N and we are trying to make a copy of a Business Week article. It printed fine to the copier but when we try and make copies of the document there is a yellow line going across each page. ...
If this only happens when copying clean all the glass under the document cover.
If this happens print and copy clean the yellow charge unit with the cleaner (see trouble guide).
Nov 04, 2010 | Sharp Office Equipment & Supplies
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when...
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Aug 24, 2010 | HP LaserJet 3015 All-In-One Printer
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP color laserjet 2840
If you are copying trough a sheet feeder or document feeder, you will need to clean a thin glass **** from where the documnet is scanned for copying.
Jul 10, 2008 | Office Equipment & Supplies
HP J5780 All in one printer
Once try to make a scan and if we are getting line even while scanning. Then perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01129408&cc=us&lc=en&dlc=en&product=3301296
Directly go to step three and then try to make a copy.
If the issue still persists then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Now try to make a copy and check for the result. If the issue still persists then reset the all-in-one.
  1. Unplug the power cord from the product.
  2. Press and hold # and 6 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Jun 05, 2008 | HP Officejet J5780 All-In-One InkJet...
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Getting grey background on documents when copying
If you are getting a grey back ground, this means you have the wrong setting- the scanner is seeing a 'photo' image. look at your controls for TEXT or LINE
Apr 17, 2007 | Epson Stylus RX425 Multifunction...
HP PSC 1610 All-In-One InkJet Printer Logo
49 people viewed this question
Clive
Clive
Thomas F. Schneider
