Question about Tascam DP01 All-In-One Recording Package Microphone
My dp01wth cd recorder says no more disc space when trying to rec
I had my recorder 4 3 years and never had a problem til now i deletted all my saved music off an tryed to create new song an iam getting message no free disc space cant understand that. there is nothing on my hard drv. its empty.wood like too mail to tascam to get it fix. i need it bad iam a dj an i uses it to do my mixes on. PLEASE SOMEONE HELP ME.
  • 189 Answers
You may wish to first verify that you have indeed erased those songs (by choosing 'erase' in the 'song' menu - see page 18 in your manual) and not simply cleared out the fat partition. You cannot erase songs on the DP-01 from your computer, you can only do this in the DP-01 menus.
If you erase all the songs from a disk partitian the DP-01 is supposed to automatically create a new blank song. So the partition or the hard disk could have become corrupt because you say you aren't seeing any song there.
If you haven't already, you could try selecting another partition to be the active one (press 'menu', select the 'disk' menu, choose 'partition' and press the > arrow key. Move the arrow symbol to the partition you want to make active and press enter - see page 36 in the manual) to see if another partition works any better.
If the newly selected partition does work, but the original one didn't you might have to reformat the old partition. Re-select it as above, and follow the instructions to reformat a partition on page 37 in the manual).
If the newly selected partition doesn't work either, then your hard disk might be corrupted. At this point you could try a disk reformat (page 36 of the manual) during which you'll have to set the partition sizes. The disk format instrcution of page 36 will walk you through that too,
Hopefully it's just something simple and you won't have to get into formatting anything.
Good luck with it.
Posted on Jan 15, 2009
How to properly get this item to record?
search google with make and model of it then manual
Mar 08, 2015 | Audio Players & Recorders
It gives error that your hard drive have 1mb free space
1. Go in control panel Add or remove programs or programs and features then uninstall the programs that you don't use or havn't used in a long time.
2. Go in control panel Folder options view tab at the top. Look for Hidden files and folders put a tic in show hidden files and folders.
Go in My Computer/Computer Click on the c drive then windows folder delete the update folders that have a $ infront of the name of the folders. Go back to Folder Options/View tab at the top. Hidden files and folders put a tic in Do not show hidden files and folders.
3. Right click on Rec bin choose empty rec bin.
4. Go in control panel / Internet Options clcik on settings next to the first delete button from the top then click on view files. On the upper roght clcik on edit/Organize choose select all. Then hit your delete key on your folder yes to conferm. Click on ok then in the next window click on delete button next the settings button you clicked on before.
5. Open notepad type del %temp% /q then save the file to your desktop name it Del.bat cloce everything out and double click the del file on your desktop.
6. Open the run command Hold the windows key down (left of the space bar on your keyboard) Press the r key. Type in %temp% Delete all the files and folders you can in that folder.
7. Right click on Rec bin choose empty rec bin.
If it still says low disk space I suggest saving your personal files and reinstall your oem system disk or add a second disk drive.
Apr 03, 2014 | Computers & Internet
I have TEAC LP-R500 Rec LPtoCD ?set tracks record 2 side of album
It may have recorded but in order for you to see it the disc needs to be finalized. This is when the TOC- Table of Contents is written and when the files/track show up.
Dec 20, 2012 | Audio Players & Recorders
Trying to record from tv set to analog press rec opt flashes for 10 sec+- then rec flashes continuously and no signal strength/vol bars
I think there is no cd in the tray or your recorder had set in pause mode .
Let me know if you need more information
Feb 01, 2011 | Sony RCD-W1 2-Disc CD Recorder
Plays fine on both decks, but does not record in any mode.when press rec, the indicator switched from saying "blanc disc" to "data disc" i got this deck used last year. not sure if it...
Check if the blank disc you are using is compatible. It sounds like the discs you are trying to record onto are not compatible with the unit OR you are trying to record in the wrong mode (Synchro v direct see below) It will only record onto CD-R or CD-RW discs. Also read the instructions for recording as there are a number of recording modes depending on menu settings.
See manual here
Jan 11, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Is there a way to record something on a dvd from the tv?
Which model do you have? Some of the GoVideo DVD/VCR units are only DVD players so you can only record to the VHS tape. If you have a DVD writer version, you may find it tedious but doable. First load the blank DVD and set the Disc Record mode (you will see an on-screen prompt) for VR (this lets you do more editing of the video) or Video (this choice is compatible with more players). Then set the REC Mode by pressing that button repeatedly (SP (2 hours per disc), LP or XP(1 hour per disc). For one-touch recording (recording the current program that you are receiving on the device), select your Channel and Audio track then press REC. If you press REC several times, you will set when the recording stops. Otherwise it will not end until you press STOP.
For timed recording, press Timer Record. Then go through all the items to set the DVD recording information. Record mode, Channel, start and stop times. The left and right arrows let you change menu sections and the up down scroll through the settings. Press Enter to save the programmed recording. Then press Return. Make sure blank media (or with enough room for the programmed item) is in the machine. On some units, you will need to turn off the machine for the Timed Recording to work.
For recording from external sources, press Input instead of Channel.
For any recording, leave a bit of extra space on the disc to Finalize the DVD if you will want to play the disc on other players.
I hope this helps.
Aug 15, 2010 | GoVideo Go Video DVD/VCR Combo
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
I cannot write data from HDD to DVD+RW
The REC Mode of the recordings was set so high that there is not enough space on the DVD to make a recording. Cannot change at this point. For future recordings, switch to LSP or some other non-quality mode.
Feb 01, 2008 | Philips DVDR3455H/37B
Recording Problems!
You may try a different style DVD disc. Are you using (+), (-), or (RW) the DVD makes a difference. Here is the manual for your product. Check pages 9 and 10. These pages tell you the type of DVD disc to use, and what speed they can be used. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Tascam DP01 All-In-One Recording Package Microphone Logo
102 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
