Question about Jenn-Air JCD2295HES Side by Side Refrigerator
My kitchenaid model kscs25ftms02 water dispenser doesnt work
My ice maker works fine i can hear the motor trying to send water but no water going thru
  • lightenergyd Mar 19, 2009
    The icemaker works fine but no water is coming out of the dispenser. When I press the lever I can hear the parts working and I heard water spraying. I pulled back the fridge and saw a water line laying in the drip pan with a screw put in the end of it (to seal the tube). When the lever is pressed a small stream of water squirts out the top, where the screw is. Any suggestions?
  • 1,214 Answers
There is a water valve located at the bottom back of the refrigerator that may have failed or is clogged with trash from the water line. Either is a common problem.
If your know how to use an ohmeter and simple tools like a screw and/or nut driver, I can give you additional instructions on how to troubleshoot. Otherwise, I can search for the P/N and you can order one. You will need to install, or find someone to install for you.
It could also be a filter problem if yours has a filter, or a water supply problem (have you checked the valve a the wall to make sure it was open?).
Posted on Jan 14, 2009
Water dispenser maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker working fine - Water dispenser nto doing anything
hi there,
sounds like the water valve may be the culprit.
can you provide the model # off your fridge please?
Sep 21, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Jul 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
443 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
