Question about Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One shuts off
When I turn it on it shuts off almost immediately.
  • 3 more comments
  • Anonymous Jan 22, 2009
    I just bought mine yesterday and everytime i go to gmail or aim or video chat it would just poof shut down. I noticed it would heat up very fast when on ac power.
  • jorluis May 01, 2009
    Hi dears, i bought an acer netbook and i cant turn it on, how can resolve it
  • Anonymous May 11, 2009
    I have the same problem... turns on and after 90 seconds turns off with no previous message
  • heatgap
    heatgap Nov 02, 2012
    Tapping virgorously on the left hand underside of the netbook (where the vents are) and the circled protrusion area* worked for me! It got the fan spinning up again...which probably got stuck due to dust, grime, or old age. Thank you so much swbrains! I'm a computer tech and overlooked the fan not spinning up!
  • heatgap
    @swbrains - Thank you! That is all I had to do. I vigorously tapped on the left-hand underside of the netbook while it was booting up...and voila the fan started spinning up again. These fans probably get stuck because these netbooks are getting old now :P and dust, grime, etc will cause tiny fans to stick. Thanks alot you fixed my issue!
Mine did the same thing -- noticed the fan wasn't running at all during bootup when the shutdown problem was occurring. Tapping the bottom ofthe case near the fan got the fan running and it booted fine after that. It happened twice in about a year's time and both times this fix worked. I'll probably take it apart soon and clean out the fan.
Posted on Dec 14, 2009
I just fixed this problem. My fan was not running. Mine would only stay on for about 60-90 seconds. I had to disassemble it and used compressed air on the exhaust fan that covers the CPU. I also tightened the screws on the heatsink to make sure it was getting good thermal contact, and made sure the fan was well connected. All is well. Use one of the guides to "upgrade RAM" to take it apart, then once you're in, clean the fan and make sure it's hooked up.
Posted on Feb 17, 2009
I had this problem with an acer took it to pc repair shop MOTHERBOARD sorry peeps this can be an expense problem. currently having same problem with my sons acer one n really hope its something silly like over heating, just plugged in an external fan, gonna leave it to cool down for an hour n reboot fingers crossed
Posted on Jan 30, 2013
  • suzanne_blue
    suzanne_blue Jan 30, 2013
    i had this problem with an acer took it to pc repair shop MOTHERBOARD sorry peeps this can be an expense problem. currently having same problem with my sons acer one n really hope its something silly like over heating, just plugged in an external fan, gonna leave it to cool down for an hour n reboot fingers crossed
Thanks swbrains!:) ..your solution with tapping helped me a lot!:)
Posted on Mar 29, 2010
    Genius:
  • Acer Master
  • 1,102 Answers
Is this a new aspire one
Posted on Jan 15, 2009
    Sergeant:
  • 366 Answers
Check if Battery is charged and if AC power supply is working.
5 Suggested Answers
  • 357 Answers
SOURCE: My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Posted on Mar 14, 2009
rubydu
  • 102 Answers
SOURCE: acer aspire 5610 monitor turns on when it boots
check fan and hdd
Posted on Jul 18, 2009
  • 163 Answers
SOURCE: When I try to turn on my Acer Aspire 5100, it
You may have a bad processor and it is over heating,or the over heating may be due to a dirty fan,which keeps the processor cooled off.Look under the laptop and see if you can get a peek where the fan is,to determine if it is actually dirty:)
Posted on Apr 12, 2010
fredgeorge
  • 91 Answers
SOURCE: My acer aspire 1670 cannot
this may be due to heat issue ot it may be a ACPI driver issue
go to device manager and uninstall the ACPI power button under system devices as well as the ACPI driver under computer
reboot the system and reinstall the chipset driver and reboot the system
Posted on Dec 26, 2010
My acer aspire 1670 cannot be turned on immediately after it is shut down. It takes about 30 minutes before it can be turned on again.
Dec 26, 2010 | Acer Computers & Internet
Why my acer aspire 4520 suddenly cant be switch on after a power cut of and my laptop shut down immediately?
this is happening cause it wasnt turn off proper and it is stuvk in a loop ..try to get all power off including battery .put it back and power it ..if it does the same you will have to open it and remove the ram memory and the bios battery and put them back and will work ..
Jun 02, 2010 | Acer Aspire 4520-5582 Notebook
When I try to turn on my Acer Aspire 5100, it immediately shuts off. How do I overcome this?
Apr 12, 2010 | Acer Aspire 5100 Notebook
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
Laptop battery problem
Try not to install the battery while its on. Power down the laptop then install the battery and power back on the laptop. Hope that helps.
Nov 10, 2009 | Acer Aspire 5050-3242 Notebook
System shuts down when opening dvd drive
The best thing for you to do in this case is send it back to Acer details can be found on thier website of how to do this. www.acer.com
If you wish to test this though, turn the laptop on and immediately eject the dvd drive whilst pressing the required key to enter the bios. Usually F2 or F12 if you can still find the Dvd drive listed in your bios when its ejected then it could be an OS problem. However if not its a hardware issue and opening the laptop will void the warranty.
I think what is happening is that when you open it in windows it causes the drive to be disconnected causing a fatal error in windows and thus it reboots or shuts down the system to prevent anymore damage.
- John
Apr 22, 2009 | Acer Aspire 5610-4648 Notebook
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
Battery does not charge
you have a bad battery. Go to Batteries Plus and have them rebuild it or purchase a new one.
ThkPoz
Jan 11, 2009 | Acer Aspire One A150-1049 Notebook
Laptop auto shuts off - will not come back on
have you checked the power coming fine. If you were working on battery mode it cud be coz of battery issue...
remove the battery & switch on the laptop in power mode.
Dec 03, 2008 | Acer Aspire 5050 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
2,510 people viewed this question
Brian Sullivan
Brian Sullivan
