Question about Kenmore 62872 Electric Dryer
Dryer not getting hot
It wil spin and seems to be working for the most part but it does not heat up.
  • 5,911 Answers
Please read the following link for advice on how to troubleshoot a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, double check the input voltage at the wall receptacle. A reading should indicate the presence of 220-240VAC. If the voltage is incorrect, you may be missing one leg of the 220 service required to run your dryer. If the input voltage at the receptacle is good, locate the terminal block in the back of the dryer (this is where the power cord connects) and check the voltage again with the dryer plugged in. A reading across the two hot leads (RED and BLACK) should indicate the same voltage. If not, the power cord may have one of the hot leads broken.
Read through the link thoroughly. These are the more common heat related issues that will cause a dryer to stop heating. This does not always indicate the failure of the heating element. More commonly, the Thermal Cut-Out (TCO) fails. If the TCO is found to be the problem, it is strongly recommended that you also replace the Hi-Limit Thermostat as well. Failure to do so may result in premature failure of the parts you replace.
Pay particular attention to the paragraph that discusses the dryer ventilation. If the TCO fails, its generally for a reason. Most dryer heat related problems are attributed to poor air flow caused by clogged vent ducting. This causes a dryer to overheat to the point of failure. Leaving a dryer in a clogged condition will cause poor drying results and eventual failure of the same components. If you cannot remember the last time you had your ventilation checked or cleaned, now would be a good time.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 14, 2009
    Problem Solver:
  • 7 Answers
Sounds like the heating element is bad.. im not sure if there is a fuse in side the machine or not but it would be worth a try to look.
My Whirlpool duet electric dryer seems to get too hot and stops working
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 12, 2014 | Dryers
Hi, i am experiencing issues with my Kenmore 80 series , model no. 110.76832500, natural gas dryer. The issue seems to be overheating or a faulty sensor. The dryer heats normally and spins fine when first...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Kenmore Dryers
Dryer does not get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Magic Chef CYG2000AWW Gas Dryer
Dryer spins - clothes wet?
check your venting as clogged or kinked ductin or venting wil cause long dry times
Feb 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer spins but does not get hot
The problem could be a faulty component such as the timer, heating glow bar, gas coils, safety or operating thermostats. First thing to do is to check the venting to make sure it is not plugged. I cover that more in detail if you wanna check it out.
http://tclaundryrepair.com/dryer
Feb 26, 2009 | KitchenAid Dryers
Dryer doesnt seem to be getting hot as it usually does
We had a similar problem with our dryer just last month. It would spin and turn on, but no heat. It turned out not to be anything wrong with the heating element--it was a tiny electrical part that had malfunctioned.
Anyway, I would recommend calling in a professional if you've already cleaned your dryer and still can't get it to work. That could save you a lot of time and money in the end.
Violet Campbell ' http://www.ayersappliancerepair.net/appliance-repair-services/
Dec 29, 2008 | Dryers
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Maytag lse7800acw
The motor is faulty. Either the relay contacts are stuck or there is a shorted winding. Best to replace the motor.
Jan 13, 2008 | Washing Machines
Kenmore 62872 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
