Question about Epson Stylus Photo RX500 Printer
"spooling" when printing TurboCAD image
I do some drawing in TC 10.2 pro. Today, the printer gets stuck, when I check its status in the printer window, it says it is "spooling". I reinstalled the driver, shut off everything again and again. I can capture the screen and paste it into Word, and it will print. Are there any TurboCAD/Epson geeks out there with a good fix? Duane
    Genius:
  • 2,985 Answers
Spooling is a PC thing not printer Printer spool is an area of reserved memory which collects date for the printer before sending off - it seems it is not big enough to cope with the image size you are dealing with. check out the Computer route to adjust the spool memory size.
Posted on Jun 17, 2007
We are having problems printing a 10' x 42" banner on our Epson 10000 plotter. We are using a Xante Symphony RIP networked to the Plotter. For some reason it stops printing at approx. 76% (3/4) of...
STEVE you have to print it as a tiled image. there is an update on the epson website for this issue. basicly anything over 90" you have to tile as two images split in half with no border in between if that makes sense. they explain it well in the update. when its something 120" x 36" lets say i run the set up at 36 x 60 then go to the page set up and there should be a box for tie image when you preview it again it shows the tiled image put back to back. you also have to tell it toreverse the print. i use adobe cs2 illustrator and it works well.
May 28, 2011 | Epson Stylus Pro 10000 InkJet Printer
Hi my printer will not print. it is saying printer spool error.
> spool error
S.P.O.O.L. == Simultaneous Peripheral Output On Line
The "spool" is a combination of disk-space on your 'C:' drive, and software to "accept" the print-image (as fast as MS Word can create the print-image), and save the print-image to disk-space,
so that MS Word can report "print completed", so that you can use MS Word, instead of waiting until the physical printing has completed.
Then, the printer-spooling software will read from the print-image file, and send it to the printer, only as fast as the printer will accept it.
Feb 05, 2011 | Xerox Office Equipment & Supplies
Cant get my AIO Photo 926 Printer To scan
hi kylefahrig,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then remove the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
NOTE: IF YOU HAVE ANOTHER PRINTER INSTALLED ON THE COMPUTER, DON'T PERFORM THESE STEPS, JUST RESTART THE COMPUTER.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver.
just update me, if you're still having issues with the printer.
Oct 20, 2009 | Dell 926 All-In-One InkJet Printer
Printer not printing
if your printer is giving you an error msg saying printer communication not available.
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day :)
Oct 01, 2009 | Dell 962 Photo All-In-One InkJet Printer
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
Reference Manual "TurboCAD Version 10," required
I don't know if this will help but your best solution would be to have a friend at a local office or school print it for you. In the US we have Kinkos, OfficeMax that will print for so much money per page.
For the manual, you could always go to the TurboCad website and perhaps see if they have a manual you can purchase. Call the US telephone support line: 1-800-833-8082, they might be able to sell you a printed copy.
Mar 08, 2008 | Computers & Internet
Mgr
go to test print on the printer panel, in there you can find nozzle check test print pattern, status check, and job info. try to select and print the job info, in the printout you will find the 10 previous jobs. status check informs you if your printers life and consumables is in near end. hope my advice cud help you.
Dec 12, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Photo RX500 Printer Logo
234 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
