Question about Whirlpool GGQ8831L Gas Dryer
Dryer trips the GFI
When i plug the dryer in it trips the GFI in the outlet, the washer does not
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
FYI, I have had the same problem and have spoken with three different technicians including one that is supported by the LG website and all say the same thing: replace the gfci with a regular outlet, even though in my case (and probably yours) this would not be to code. If the manufacturer of the dryer is saying that the dryer should not be plugged into a gfci outlet (their words), I'm not sure there's anything that can be done about it. Mine also ran for 5 years in the gfci outlet with no problems. If you find another solution, (or can recommend any technician that takes this issue seriously) please post!
Posted on Aug 10, 2016
    President:
  • 1,214 Answers
It sounds as though some component in the dryer has a high resistance short to ground. Not enough to burn it up, but enough to allow the current in the hot leg of 120VAC to be greater than the current through the neutral leg.
It is also possible that the ground is a low resistance short to ground. Have you tried to temporarily plug the dryer into a non GFI outlet (use a heavy duty extension cord)? If so, does the breaker for that circuit trip?
DO NOT LEAVE THE APPLIANCE CONNECTED USING AN EXTENSION CORD! THIS IS ONLY TO TEST THE APPLICANCE FOR A HIGH RESISTANCE SHORT.
Either way, I would be suspect of the motor first, and the pilot igniter circuit 2nd. Please provide more information as to what you find in the test above.
Posted on Jan 19, 2009
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
GE Profile Harmony washer won't power up and trips gfi
Did you replace the inverter board?? It is inside the tan plastic box in the bottom of the control panel I think on the right side. That controls the power supply to a good part of the machine and drive system. Has to be a direct short somewhere to trip the breaker.
Mar 31, 2015 | GE Washing Machines
Is there a reset button
First, plug a fan or hair dryer into the plug to make sure it has power, if not, check to see if the GFI plug hasn tripped. All electrical plugs that are near water have to be on a dedicated electrical line that has a trip-breaker (GFI) built into the plug. Try unplugging the washer for several minutes to reset the electronics. Those are the only two quick fixes I can think of. If you have an electric dryer, it will have its own 220v plug and won't be affected like the washer. If the dryer is gas and is plugged into the same outlet, try unplugging the washer to reset first before you call a repairman for the washer. If you have homeowners insurance, they may cover the damage.
Jun 21, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Gfi outlet trips right before the final spin cycle. This is on a top load kenmore 80 series washer. I replaced the timer but the problem still exists. The timer seems to be in a pause mode. In other words,...
Motor driven appliances can trip GFI outlets when there is no problem at all with the appliance. When a large motor first starts, it draws more current for a short time and some GFI outlets will trip (others may not).
Are GFI outlets required by code in your state/county for washing machines? If not, replace the GFI with a standard outlet. If so, replace GFI with a higher quality GFI outlet.
Nov 30, 2012 | Washing Machines
How to stop my whirlpool washer from tripping gfi
If it is tripping the GFI I would say you have created a short somewhere. Check that wire has not been braised, check the plug for signs of burning, check outlet for signs of burning. Plug another device into the outlet to see if something else trips the GFI. If something else trips it then you could have a bad GFI outlet. These are the basics to try first but could be a number of things beyond this.
Aug 31, 2012 | Whirlpool Washing Machines
Gfi installed yesterday on washer 120 v outlet. washer is maytag 3 years old and gfi began tripping during washcycle. can it be washer 3 pronged cord is not grounded at connection in rear of washer?...
The ground not being connected does not tirp thr gfi. The gfi senses the current between the two legs it will trip when the current returning to ground (neutral) exceeds 5mili amps. This is for personal protection. If you have a gfi circuit breaker disconnect the black wire from the breaker, if it does not trip you likely have a groung fault in the washer. If you have a dryer or other metal object that is grounded (Bonded) you may get a shock from it, also standing (barefoot) on a concrete floor may cause the same. ( bonded is a gronded conductor that attaches all metal parts of a electrical curcuit together) a hot lead goes to ground is a dead short and will trip any breaker.
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
The washer fills just fine, but when it starts to agitate, it trips the GFI outlet. It's not the outlet, we tried 3 of them. The washer works just fine if it's plugged into a non-GFI outlet. Any ideas?
I do home inspections, and this is a no-no! GFI devices are not real happy with inductive loads, such as motors and refrigerators. Generally during home inspections, we find that GFI's older than 10 yrs. have a 75% failure rate using a sophisticated tester. The 5 yr. old devices are at 50%. I'd replace that outlet with a single outlet, dedicated to the washer. If it's near a sink, then you're required to stick with the GFI. I'd just repalce it with a new one. Good Luck!!
Jun 11, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
Whirlpool GGQ8831L Gas Dryer Logo
189 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
