Question about Philips 42FD9934 42 in. HD-Ready Plasma Television
Philips 42FD9934 42in HDTV plasma - no Pic red light 4 blinks
My Philips 42FD9934 has no picture and red light flashes in 4 blink sequence. I do not have owners manual. Is there a troubleshooting code specific to 4 blinks?
Thanks
  • 1 more comment
  • BuckingNine Jan 15, 2009
    My 50PF7321D plasma does the same thing...
  • dhainesjr Jan 26, 2009
    I think I have same problem, Picture goes out and red light flashes.
  • Anonymous Feb 22, 2009
    unplugging & replugging power cord worked a half dozen times, then didn't. unplugging power cord for several days worked and then didn't. repairman came over and switched power cord plug-in location - worked, now doesn't. other website indicates hundreds of people with same issue. i'll be calling repair company to tell them it wasn't the "power strip" afterall - duh.
Tiene lus roja y no prende
Posted on Mar 04, 2011
We have a Philips plasma 42PF7320A/37 tv. When we plug it in, all we get is a red blinking light. We took the back panel off and looked at the capacitors and they look fine. What else should we check...
cOUNT THE NUMBER OF RED BLINKS AND MAKE NOTES OF THE SEQUENCES. Third will tell tou what is wrong with the tv during it's self diagnostic.Google the make and mogel numbr and seaqrch you anwers from ther.
Jul 09, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
No picture,red light flashes on panel 50in plasma cineos philips
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
May 05, 2010 | Philips 50PF9966 50 in. HDTV-Ready Plasma...
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips tv blinking red light
I've seen this problem before with Philips. 6X3X blink was the X-sus or Y-sus boards. In other words, the TV cannot make the picture on the screen properly, so it won't even try and will shut down.
I've also had difficulty getting these parts from Philips (even while being an authorized service center). If you have an authorized service center near you, you might want to give them a try because I don't believe they were too expensive, just hard to get.
I hope this helps you...
Jan 08, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Cannot turn it on using either the remote or set top switch. There is a click and red light blinks but no sound or picture. For some time if I hit the on button 5-6 times it would work but now it does not...
the initial symptom is usually caused by microprocessor as it is not initializing correctly. followed by 4 blink error which is i2c communication failure also specific to microprocessor would recommend replacing small signal board as microprocessor is located on that board
Jul 21, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Philips 42FD9934 42 in. HD-Ready Plasma Television Logo
628 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
