Question about Microsoft Flight Simulator X for Windows
No engine noise when viewing aircraft outside the cockpit
When I activate the button to get an outside view of the aircraft there is no engine noise at all. As you take off you can hear the wheels making a noise on the strip but when the aircraft lifts there is no engine noise whatsoever. There is plenty of engine noise in the cockpit when I change the view to inside.
  • alexander_ir Jan 15, 2009
    I also have FS2004 and the outside noise of the engine on all aircraft works perfectly. On FSX it is completely silent
    Problem Solver:
  • 6 Answers
Maybe your 're to far away from the engine and you cant hear it, even in real. but i dont think yhats it. check your audio settings.
i cant think of anything better, maybe u just need a patch...
kilbeam99
Posted on Jan 15, 2009
  • kilbem99 Jan 16, 2009
    ok, srry i didnt help
    kilbeam99
2 Suggested Answers
  • 51 Answers
SOURCE: No engine Noise outside aircraft
Thats just the way the design it it does the same for me it isnt wrong.
Posted on Feb 11, 2009
Why can t commercial airplanes use electronic view screens, like on Star Trek?
Modern Jet airliners already have electronic screens that depict the ground, the sky, maps, terrain and many more things, They are known as "Glass Cockpit" aircraft. These aircraft can land in Zero visibility fully automatically without the pilots having to see out of the window at all, just viewing the screens. The problems are in training of the flight crews. Full automated approaches and landings are far more exacting on the flight crew than a normal visual landing and crews have to be specially trained and certified to do them. The thought that on an automatic landing the pilots just sit there and do nothing is far from reality. The procedure is one of intense concentration and if the aircraft so much a twitches the pilots will abandon the approach, they have to watch everything. Training flight crews is a very expensive business and an international operator would have to have about nine crews for just one aircraft. Training those crews to operate with just view screens would blow the training budget out the bank. No matter how cleaver these modern jets are the fastest computer on board is still the one between the pilots ears and using all his senses and especially sight through a window will be with us for some time.
Jan 04, 2017 | Aircrafts
How to know if the aircraft is airworthy?
From a pilot's point of view, every aircraft comes from the factory with a checklist of things to look at specifically before every flight to ensure airworthiness. It's generally called a walk-around inspection, checking flight controls for security and condition, tire condition, engine for obvious problems. propeller, fuel and oil quantities. and many other things. The walk around also includes checking to ensure all required paperwork is there including weight and balance, airworthiness certificate, aircraft registration, operator's manual. etc. I would also check the log book to verify the transponder check was done within the past 24 months and the annual or 100 hour inspection is current. From an A&P mechanic point of view much the same applies, however I would look much closer at the maintenance logs for engine and airframe.
What does exp.sim mean?
In Live View mode, evaluative metering is always used to determine correct exposure, though exposure compensation is available. The Exposure Simulation function will attempt to recreate the exposure level that would be obtained with your current settings on the LCD display. This may raise noise levels of the live view feed beyond what could be expected in the final image, since it must operate with a fast enough shutter speed to achieve its required refresh rate. The aperture also remains open by default, and so the exposure simulation doesn't indicate the areas in focus unless you configure the Set button to provide depth-of-field preview, and then hold it down during live view. Exposure Simulation will attempt to continue even with depth of field preview active, though this may raise the live view noise levels even further. If you pass outside the range where the live view feed can simulate your exposure, the "Exp. Sim" icon near the bottom right of the LCD will blink, as a warning.
Nov 24, 2013 | Canon Cameras
Where is the cockpit located?
The cockpit is always located at the front of the plane. It consists of the pilot of the plane, his co-pilot, and at least one or two observers.
Aug 29, 2012 | Champion Sport & Outdoor - Others
SPOT VIEW FIXED
You need to assign what view you want to the cooley hat on your controller in FSX\Settings. Rethe Zoom, press the backspace key to reset it, then use the + and - keys to zoom in and out.
Apr 22, 2009 | Saitek Pro Flight Yoke System Flight...
MY POI in Mio C220
The manual doesn't match the software :)
This has been driving me crazy too.
Answer:
You can't do it from 'cockpit' view.
Press 'Menu -> Home -> Map -> Bottom right corner button (to show 'route to', 'add via'...) and the rightmost button is 'Add POI'.
To get back to cockpit view, press 'Menu -> Home -> Cockpit'.
Mar 28, 2009 | Mitac Mio C220 GPS Receiver
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Jan 16, 2009 | Microsoft Flight Simulator X for Windows
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Microsoft Flight Simulator X for Windows Logo
236 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
