Question about Panasonic PV-DV103 Mini DV Digital Camcorder
Can't record or playback
I have a problem with my camcorder. I had this problem before but now I can't seem to fix it. It won't record or playback. I can't clean the heads because it wont play anything. I just get a blinking power light and it turns off. Can anyone help? I notice that someone has a similar problem. Were you able to fix it? The manual tells me that it is a dew problem but I get no indication that it is. So can anyone help?
  • mich102969 Feb 09, 2008
    when I push the power button on my camcorder it turns onand shows battery is charged but the power button flashes and then shuts off and you can't record or playback anything you can see what you are lookingat in the screen though
  • antabr Mar 09, 2008
    I have the exact same problem. I was trying to play back a home movie and i can't play it at all
  • 95 Answers
When the red light flashes the camera either has a fault with tape mech or the lens unit. This should be checked by a panasonic technician.
Posted on May 31, 2008
SOURCE:
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
TAPE MECHANISM WON'T ROLL THE TAPE, IN EITHER RECORD OR PLAYBACK
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Apr 02, 2012 | RCA CC4393 VHS Analog Camcorder
Camcorder won't record or playback,has distortion and low volume.Is it just real dirty?
Try to find a video cam ,,head cleaner,,at elonric s store ,,find online,,,try cleaning the heads down in there with alcohol and a q tip,,,also,,good luck,,but thats what it is just dirty,,
Dec 23, 2011 | Quasar VM-L152 Camcorder
What does wrong format mean with a canon zr300 camcorder? My buddy shot some footage on a high end camera and my zr300 camera at playback reads "wrong format playback not possible.
Different camcorders have different recording formats. Some ar HD, some are 16x9, etc.
A camera that isn't designed for a particular pre-recorded format cannot playback that recording.
Rick
Sep 06, 2010 | Canon ZR300 Mini DV Digital Camcorder
No playback pics. Blue screen.Can't record.Used x2 since service.
I just made contact with a service tech who seems very competent and who won me over. Have problem with video and audio dropout similiar to dirty heads on a 10 year old DCR-VX2000 but which is a larger problem attributed to worn parts which will need replacement. Do not know how old your unit is, but will share name of person/company if you wish. Only thing that worries me is if you by chance had had yours repaired by them!!! They are a Southern California company.
Jan 27, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Canon zr800 video problem
One head cleaner cassette later the problem was fixed. Not only do you get Noise on the video you can actually get no video at all if theheads are dirty enough I guess.
Sep 14, 2008 | Canon ZR800 Mini DV Digital Camcorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Sep 13, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Panasonic PV-DV103 Mini DV Digital Camcorder Logo
214 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
