Question about Refrigerators
Water/ice dispenser not working
We have an LG LRSC26941SB fridge. The water started trickling out slowly from the dispenser, so we figured it was time to replace the filter. We replaced the filter and the water worked for a while, then starting trickling out slowly, then stopped altogther. It also does not produce ice. We even tried to buy a different filter just in case with no luck. LG reps are no help
    President:
  • 1,214 Answers
Depending on the age of your house, large chunks of minerals may have dislodged in the water piping system, and is flooding the filter cartridge with trash. I had this happen recently on a 15 year old house that water stopped flowing in 4 cold water faucets of the bathroom.
Try this -
1) Roll the fridge out from the wall
2) Turn the water off at the wall.
3) Disconnect the water line from the back of the fridge
4) Get a bucket and stick the line into the bucket.
5) Slowly open the valve and see if water comes out. If it does, let it run for 20-30 secs at a decent flow, then turn off. If not water comes out, then you have a different problem. The cause may be the same, but it's not the refrigerator.
If water does come out, check the bucket to see if there are chunks of mineral buildup in the bottom, or floating in the water.
If there are minerals, then again, let the line run until the water runs clear. Open the valve as full open as you can to increase the water velocities and flush the chunks. Also, if no water comes through the tube, there may be trash in the valve itself, and you will likely need to call a plumber to repair unless your handy. I can describe how to repair, but that is another subject.
If everything flushes clear and you have flow, then get yourself a new filter, and try again. If there was mineral buildup, it is possible that some got through the filter and has built up inside the refrigerator water tubing. That again is another issue that I can help you with.
Posted on Jan 14, 2009
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
LG fridge LRSC26915SW -= water dispenser and ice are not getting water
Replace water filter, this unit had a issue with restrictions in filter due to a design issue. Water valve is all so called a water pump from many people.
Aug 17, 2012 | LG LRSC26915SW 36" Side-by-Side...
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Cant get water out of the fridge door
hello allamericananp,
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
314 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
