Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag LSE7804ADE Top Load Stacked Washer / Dryer
Installed washer in basement, but had to extend the drain hose to 7 feet. Installed a check valve so that water would not drain back. Worked fine the first load but all other loads on the spin cycle all the water does not go out and it spins very slowly. If I drop the hose to floor level on this cycle it works just fine, but I have 2 1/2 gallons of water in a pail to carry upstairs. My wife is unhappy. Do I need a stronger pump as I cannot lower drain pipe. Thanks.
  • Ronald Moxam Jun 15, 2007
    Further checking it seems that the water is removed completely after the wash cycle. It seems be really slow on the rinse and spin cycle and does not empty completely, except on a small load were it works perfectly. If the pump can remove all the water on the was cycle why not on the rinse cycle? Leads me to believe something else is wrong other than the pump.
    New Friend:
  • 129 Answers
You'll need to by a sink kit at any hardware store and a sump pump , be advise at the place you buy . good luck .let me know take care
Posted on Jun 15, 2007
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
WASHER ISN'T DRAINING
Let the draining out hose in a lower surface than the washing machine placed surface. Also check for any blockage in the draining hose.
Oct 27, 2012 | Maytag LSE7806A Top Load Stacked...
My washer won't stop filling when i turn it on! It drains fine, but when I turned it on, it wouldn't stop filling.
If the water stops when you press the timer in then it is the hose to the water level switch or the switch itself. If you have to turn the water off to stop it then it is the fill valve( where the hoses connect)
Nov 29, 2010 | Maytag LSE7806A Top Load Stacked...
I put too big a load in my washer, and then it overflowed. I drained it and unloaded it, but when i put in a new load, it overflowed again all over the house. What's going on? how do I fix it?
pull the front panel off you might find a small hose going from the control panel to the tub see if it came off if so just re-attach. If you have to turn the water off to stop the water then it is the fill valve and check the drain hose from the tub to the pump that it is still attached.
Washer not working
Hello, It is most probably either the water valve shut or the hose kinked also check that the drain hose is not blocked also.
Hope this helps.
Thanks
May 23, 2010 | Whirlpool LTE6234D Top Load Stacked...
Top load stacked washer, won't pull water into machine, just
check hoses are not kinked /filter a the fill hose solonoid valve is clear if valve is okay should work...
Mar 31, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washer outlet hose - how high can it pump?
sur thats a fine height, i wouldnt go past 8ft
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
485 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
