Question about HP Officejet 5610 All-In-One InkJet Printer
Unable to finish installing software after printer connected
The box tells me to connect the printer but when I do, the installer stops and the only option I have is to cancel.
    President:
  • 8,637 Answers
Try disconnecting the printer from the computer and reinstall the software and when the program asks you to plug in the printer, do so an it should work. Bud
Posted on Jan 14, 2009
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 | Computers & Internet
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
How can I install the mp470 printer onto my laptop without the installation cd? It has been lost and cannot be located but I need a printer!
Try this!
Turn on your laptop and let it finish loading the desk top. Then turn on your printer (but dont connect it to your laptop yet). After the printer has powered up, connect it to your laptop. Watch the laptop screen on the lower right hand side to see if it acknowledges the printer now connected and automatically searches for the necessary drivers. If it does, then follow the prompts and it will tell you when its finished and the printer is ready to use.
If you connect the printer and the pc does not acknowledge that it has been connected, then you will need to download the software to run the printer from Canon's website. Just go there and enter your printer model and download the software for free.
Make sure you install the software without the printer connected to your pc. Connect the printer afterwards for best results.
Sep 27, 2010 | Canon PIXMA MP470 All-in-One Printer
Getting "printing application has stopped working"messaage
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark " " Series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows."
To install:
1. Make sure no other programs are open.
2. Insert the CD and wait for the installation window to appear.
3. Connect the USB to your computer when prompted to do so. If an "Add New Hardware Wizard" appears when the cable is connected click on "Cancel."
4. Click on the "OK" button on the Install screen to begin running the software. Follow the prompts and accept the Licensee Agreement to allow the software to load.
5. Once the software has loaded, click on "Finish."
6. Once the software has loaded, you will be able to click "Finish." Your software is now installed.
Aug 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Unable to install HP F380 drivers on Vista
well first of all uninstall the driver or drivers by going to the Control Panel, programs etc, if there driver is installed . Reboot, Now can you try another usb lead ? http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=&cc=us&lang=&product=1128296 now look at the post called Critical Update to Correct a PC to Printer Communication Issue download the HP Full Feature Software and Drivers install and connect the printer when prompt. Regards GeWiz
Jun 15, 2009 | HP DeskJet F380 All-In-One Printer
Connect my labtop to my printer
You need to install driver software.
Download driver software from website below:
Download Brother MFC-5460CN
On the download page select your country, then select DRIVER on the first box, your windows version etc.
Istall driver software after download has finished with printer USB unplegged, that is important, the software will tell you when to connect the printer.
After installing the driver software and restarting you can also install the utility software.
Mar 05, 2009 | Brother MFC-5840CN All-In-One InkJet...
Computer can not find bluetooth device printer HP Photosmart C
Step one: Install the softwareRe-install the software so that the appropriate choices can be made during the installation to resolve the issue.
  1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
    NOTE: If the software installation does not start automatically, click theStart (c00845897.gif ) icon. In the Start Search text box located above theStart (c00845897.gif ) icon, type D:\setup.exe , where D is the letter of the CD-ROM drive, and then press Enter .
  2. On the User Account Control window, click Continue .
  3. Follow the instructions that display on the screen to install the software.
    NOTE: If the User Account Control window displays during the installation, click Continue .
  4. When prompted to choose the connection type, select Directly to this computer using a USB cable and then click Next .
  5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
  6. Click Next .
  7. Follow the instructions that display on the screen to complete the software installation.
Step two
AND STEP THREE
GO TO URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00845953&lc=en&dlc=en&cc=us&product=447858
Dec 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
Connecting the printer to a bluetooth note book
Installing the Printer in Windows Vista Using Bluetooth
Install the software so that the appropriate choices can be made during the installation to resolve the issue.
Tips & Tricks: If the software installation does not start automatically, click the Start icon. In the Start Search text box located above the Start icon, type D:\setup.exe, where D is the letter of the CD-ROM drive, and then press Enter.
2. On the User Account Control window, click Continue.
Tips & Tricks: If the User Account Control window displays during the installation, click Continue.
4. When prompted to choose the connection type, select directly to this computer using a USB cable and then click Next.
6. Click Next.
Step two: Install the Bluetooth dongle
1. Insert a Bluetooth dongle in an available Universal Serial Bus (USB) port on the computer. Windows Vista automatically installs the driver for the dongle.
2. If the printer does not have built-in Bluetooth support, insert a second Bluetooth dongle in the Bluetooth dongle port of the printer after the drivers for the first dongle are installed. (If its an HP bt300 or bt450 then the drivers can be Downloaded for the same from hp.com similarly as we download the drivers for the printers)
Tips & Tricks: This step is not necessary for devices that have built-in Bluetooth support.
3. In the System Tray, right-click on the Bluetooth icon and then click Add a Bluetooth Device . The Add Bluetooth Device Wizard opens.
4. Select the My device is set up and ready to be found check box and then click Next .
5. Click the name of the printer.
Tips & Tricks: If the name of the printer is not displayed, verify that the printer is turned on and then click Search Again . After the name of the printer is not displayed, click the name of the printer and then click Next .
6. On the Do you need a passkey to your device? dialog box, select the appropriate check box and then click Next .
7. On the Completing the Add Bluetooth Device Wizard screen, click Finish .
8. On the Found New Hardware window, click Don’t show this message again for this device .
Tips & Tricks: Multiple Found New Hardware windows might display. Click Don’t show this message again for this device each time the window displays.
9. On the User Account Control window, click Continue.
10. Click Finish.
Step three: Update the printer drivers
1. Click the Start icon, right-click Computer, and then click Properties.
2. Click the Device Manager tab.
3. Click the + sign next to other devices to expand the list.
4. Under Other devices, right-click the name of the printer and then click Update Driver Software.
5. Click Browse my computer for driver software.
6. Click let me pick from the list of device drivers on my computer and then click next.
7. Under Common hardware types, click Printers and then click Next .
8. Under Manufacturer, click HP.
9. Under Printers, click the name of the printer and then click Next.
10. On the Update Driver Warning window, click Yes. Windows Vista installs the driver for the selected printer.
11. On the Windows has successfully updated your driver software window, click Close.
12. Verify that the drivers are installed correctly.
a. Click the Start icon.
b. Click Control Panel.
c. Under Hardware and Sound, click Printers.
d. Right-click the name of the printer.
e. Click Properties.
f. Click the General tab.
g. Click Print Test Page.
13. If the test page prints successfully, the printer is installed correctly.
Tips & Tricks: If the test page did not print, verify that the correct printer was selected .
Oct 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
