Question about RCA F36650 36" TV
Channels just change on their own
A few days ago, I noticed the channels on the TV were just changing on their own. At first it was occasional, but it has progressed to constantly changing channels. It goes from 0 to 99 and then recycles, staying on each channel about a "second". I thought it might be the remote control so I removed the batteries. The problem persisted. I haven't been able to find a manual on this model so don't have a clue as to where the problem is or how to fix it. I am electronic technician so I'm comfortable working on electronic problems when I know what they are and have service manual.
  • Daniel Eley Jun 15, 2007
    Thanks so much. I tried it and unstuck one, and the channels are remaining stable, but think I'll order the part and replace it as you suggested.
    New Friend:
  • 129 Answers
Easy fix the control panel switches on top are the problem ,one of them is stuck . . needs to be replaced you can obtain the part from partstore.com just type your brand and model # if you need more help let me know
Posted on Jun 15, 2007
  • Luis Amado Jun 16, 2007
    I'm glad to know that you solved the problem
    ,in case you need something else..you know im here ! Anytime !! Thanks for your vote ,we did it ! another problem solved, thanks
My remote wont work called about 3 weeks ago for replacementno response... and my tv is changing channels on its own,
You have to get nasty with the manufacturer at times to get what you want. No reason a remote can't be replaced in a few days; however, the problem seems to be the TV itself. If the remote is not active, and you experience channel changes automatically, it may be the TV receiver section alone. Call the company and mention that without the remote energized you have channel changes, they can run you through diagnostics to find the problem.
Feb 04, 2018 | Televison & Video
No picture
your projection bulb needs replacement i think...if i got you clearly!
Aug 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
Need an Input to hook up Dish network/xbox 360
Sometimes its tricky with those buttons on the front but with most tv's you can get to the menu and change inputs.
One you figure that out you will want to go back in and add that input as a channel in the add/remove channel section then you will be able to get to that input by just changing the channel down below 2
( another way to do this would be to run the auto program with the devices on and see if it adds them that way)
Sep 18, 2009 | Emerson EWF2004 20" TV
My tv is stuck on a channel
You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
Dec 15, 2008 | Proscan PS32125 32" TV
No picture, just an abstract pattern
it depends if its just that input or the whole tv itself if it works on other inputs it may not be to bad to fix, but if its the tv itself it depends on how old it is and how much you paid. it could wind up costing quite a bit. so take all those things into consideration. it might just be time to upgrade
Jun 05, 2008 | Sony KP-53HS10 TV
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
