Question about Vivitar Vivicam 5105s Digital Camera
Camera will not switch off when lens cover is closed
This happens because the camara already belives it is off. This is a problem i have had with my vivitar camara as well.
Posted on Jan 14, 2009
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Cybershot DXCS60 carl zeiss vario-tessar auto lens cover is sticking closed
There is a switch at the back of the sliding cover of the lens that is on when the cover is slided down (lens uncovered). You should try to take off the back cover of the camera where the sliding cover is and try to fix that switch.
Jul 28, 2008 | Cameras
Lens cover
Try giving the camera a fewsoft but forceful whacks by the lens cover area. Hard enough to possibly unjam the cover but not so hard as to cause more damage. Best to use your middle finger and tap on it like you're typing really hard. Then try to cycle it open/closed a few times. If that doesn't work it's a mechanical problem which needs to be addressed by a repair shop.
Sep 10, 2007 | Sony DCR-DVD653E DVD Camcorder
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Cybershot camera lens cover closed
Follow the steps below to troubleshoot if the lens will not open, retract, or extend. WARNING: There is a risk of hardware damage. Do not attempt to manually force the lens in or out. Doing so may damage the camera. NOTE: Because each of these steps represents a possible solution to this issue, check the camera status after completing each step. Ensure the battery is adequately charged or connect the AC power adapter (if applicable). Perform a power reset. If the camera lens is still not operating correctly after completing the troubleshooting steps suggested, service will be required. Hope this helps
Aug 23, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Vivitar Vivicam 5105s Digital Camera Logo
66 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
