Question about Dell Inspiron 6400 Notebook
I have a desktop dimension 6400 and it goes to black screen i pressed f12 and went thru every thing and pressed enter it goes back to black screen
  • DEKR
    DEKR May 11, 2010
    when did this start to happen
  • 3,940 Answers
Sounds like you are having a boot issue with the hard drive.
Try booting to your XP CD from the F12 menu and running CHKDSK /F from recovery console
Posted on Jan 25, 2009
ERecovery Management
Mite try taking the disc out when rebooting
Apr 14, 2017 | Gateway ZX4351-47 21.5-Inch All-in-One...
Ok hello i just got a free dell dimension 4700 and i know its wayyy out of date i just like tinkering with it i have a hp laptop g62 and everything but anyway back to what i was wondering ok i turned it on...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
try uninstalling a few unnecessary programs
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task on restart
then defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer
also select users you will see who is using your computer
hope this helps
Jan 13, 2011 | Dell Dimension 4700 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
When you first start your computer how do get it to read the disc first?
You go into Boot Menu, and set the - first boot device to CDROM.
The computer will then read what is in the optical drive, first.
Computer off, press the Power On button. Watch closely for the blue dell logo.
Looking at the bottom of the monitor screen when the blue Dell logo comes up, you will see - F2 = Setup.
At the top right of the screen you will see F12 = Boot Menu.
This screen goes by F-A-S-T!
As SOON as you see the blue Dell logo press the F12 key.
If you miss this small window of opportunity, just wait for Windows to fully load, then click on Start, Turn Off Computer, and Restart.
If Windows is not loading, then press the CTRL, ALT, and DELete keys at the SAME TIME. (Not shouting)
This will restart your computer so you can try again.
Upon entering Boot Menu you cannot use your mouse anymore, you have to use the keyboard.
The Boot Device Menu has the devices listed, and each device has a number next to it.
At the bottom of the menu, type the number that is next to CDROM, then press the Enter key.
This is Dell Support, and the main page for the Dell Dimension 4700 Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Left-click on - Entering System Setup
Should you have any questions concerning this, simply state so in a Comment.
May 03, 2010 | Dell Dimension 4700 PC Desktop
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but no matter option i choose it aslways comes back to the black screen
if you have the windows xp disk, boot from it by pressing F12 upon turning on your computer. press 'R' to choose recovery console. you might be asked which windows installation you want to start, just press 1. when you see the console, enter the command 'fixboot' without the quotes. then type exit to restart your computer. hope it helps.
Mar 14, 2010 | Dell Dimension 8200 PC Desktop
Cannot reformat Dimensions 4600 I tried F11 but it won't let me restart
If you are going to reinstall the operating system on the dimension 4600, while it is on insert the Operating System CD inside the drive then press and hold the power button to turn off system. When you turn it back on press the F12 Key once on the Dell Logo and that will take you to the Boot Menu. Choose the one that says IDE or Onboard CD / DVD Drive then press enter. If it asks you to press any key to boot to the CD then press enter again. Then just follow the normal prompts for reinstalling the operating system.
Apr 05, 2009 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 will not boot from cd drive first
Go back to the Dell BIOS screen and change all setting back to the default settings. Put in a Bootable CD and press F12, this will give you boot menu. Then you can boot to any device that you need to.
Please rate my response
Feb 17, 2009 | Dell Dimension 4600 PC Desktop
Start up problem
try to load in safe mode if the problem persists than you have to repair or reinstall the OS
May 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Inspiron 6400 Notebook Logo
76 people viewed this question
Alun Cox
