Question about Hoover H3060 FloorMate SpinScrub 800 Upright Wet/Dry Vacuum
Suction problem? The drain tank goes into overflow mode and stops sucking up water
I have just received a new Floormate and I need a solution - Help! I used it for the first time today and it was great except for this problem - it continuously acted like it was going into overflow mode and the suction would cease and the machine would stop sucking up water. I had to constantly turn off the machine, release the tank to relieve the pressure to allow the flap to drop, and restart. However, it would happen again sporadically - sometimes the next minute, sometimes the next 5 minutes. After reading about possible solutions on this board, I went through several troubleshooting steps: I've checked the filter (it's clean), made sure the drain tank was empty and I checked the hose door on the side (closed). So I'm out of ideas - help!!! I really like how clean my floors are so I really want this to work out. Thanks
Re: Suction problem? The drain tank goes into overflow...
I had the same exact problem. The little plastic thing that hangs down is too light; my husband taped a quarter to it securely, and that solved that problem! Of course, this is January 2008, so I hope you haven't suffered with this problem all this time. Mweddell.
Posted on Jan 03, 2008
0 characters
3 Points
Hoover floor mate sucks up water while in the wash position
They do that. They pickup the water in all stages but lower the squeegee to different heights. At no point does the suction turn off.
Jan 20, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
I have a hoover floormate h-2800 that does not suck up the water
this is a great vacuum. however it does require an extensive cleaning every now and then. diaassembly is required for this. there is a hose that goes from pick up to the tank. make sure this is clear. also your filter should be clean and dry.
May 20, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
No suction
open the tank where dirty water goes and make sure the float is down and not stuck ...when its full of dirty water the float raises with the water level so that the vacuum doesnt keep sucking and overflow
Jan 03, 2010 | Dirt Devil CE5500 Floor Keeper Upright...
No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Oct 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate not suctioning water back up
I love my floormate so muck that when my first one stopped vacuuming, I bought a new one - just figured it died. Then my new one worked well until one day, it suddenly stopped.
I discovered that the filter attachment holder (the clear plastic cover over the filter) has to click into place. I guess this might not be a problem for some, but I thought it just sat there over the filter. I finally pushed pretty hard (mostly in frustration at first) and it clicked into place. Now the suction works fine.
Jul 11, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floor mate stopped picking up the water
Usually when this happens, it has to do with a dirty or bad filter(#45, 40112050). Or the recovery tank isn't seating like it should. Maybe this picture will help.
Feb 24, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
buy a new solution tank. the problem might be that your not rinsing the tank with clear water after use and the soap hardens on the release button of the tank.
Feb 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Low Suction
Empty the recovery tank; it may be full
and the automatic shut-off engaged.
Make sure filter and filter lid are properly
Make sure tanks are locked in place.
Check the filter and clean if dirty.
Make sure nozzle is replaced properly
and locked
Apr 30, 2007 | Hoover H3030 FloorMate SpinScrub 500...
My hoover floormate won;t suck/ suction anything!
Things to check: Check again that the pipes aren't clogged. Check all the way through from where the muck goes in to where it's supposed to end up, paying particular attention to places where the pipe narrows, goes round a bend, or changes material. Check the machine doesn't just need emptying. Wet/dry machines usually have some sort of float operated stop valve to stop you flooding the motor when you've filled it with water. Make sure this isn't stuck shut. Check everything from the impellor right back to where the muck goes in is airtight. It doesn't take a huge hole to lose you a lot of suction. Pay particular attention to places that are meant to come apart routinely, and places where hoses join to hard fittings. If in doubt, run the machine and listen for sucking noises. If there's a filter between the fan and the air outlet (there usually is) make sure it is clean Assuming the motor is running, check it is turning the fan impeller. Hopefully, one or other of these will get you somewhere. A.
Apr 06, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3060 FloorMate SpinScrub 800 Upright Wet/Dry Vacuum Logo
123 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
