Question about Frigidaire PLEF398AC Electric Kitchen Range
Looking for heating lower heating element for a wall oven.
This element is a 1950's thermador cat no W0-18AR. Ser. No. 034321.
element is approx 14 1/2" deep and 13 1/2 " wide the unit is in the shape of a double U.
The oven is 22 1/2" deep X 21" wide and 27 1/8" high
    Genius:
  • 1,847 Answers
May i have the make and model no. of the kitchen range.
Posted on Jan 14, 2009
    Genius:
  • 3,422 Answers
HI,
I'll let you know if there is any heating element is available for this model
Lower element does not heat up.
did you test it? could be bad. may be relay board, burned/broken wire, safety thermo or a bad solder connection on the board.
Feb 01, 2014 | Thermador SM272 Electric Double Oven
Thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Mar 01, 2008 | Ovens
Burnt wire at spade connector
If you are unable to catch the wire through the front of the oven where the terminals go through then you will have to pull the oven from the wall and remove the rear panel. Of course make sure the power is off before attempting the repair.
Nov 17, 2013 | Thermador SMW272 Electric Double Oven
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
Lower heating element of oven does not heat at all. Think we saw it sparking before it quit working, not sure why it would do that. Oven is very clean, nothing on walls or on element. Was recently cleaned...
The element sparking and short circuiting has nothing to do with the cleanliness of the oven. An element will break down internally and short circuit due to it's age or hours of service. Have a look at the element to see if there are any holes/blow marks on it. If there are it requires replacement. Sometimes the element will look fine but will still be faulty.
Feb 26, 2011 | Thermador Ovens
The lower heating element on our Thermador oven arced and snapped in two. I'd like to replace it myself. Just wondering if the new heating element can just be snapped into place with minimum expertise,...
Most elements are very easy to remove and replace....there are a few clips holding them in place and a screw to hold the wire at each end of the element.
MAKE SURE to turn the power off before attempting the replacement...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 26, 2010 | Ovens
Heating element in upper oven heats to about 300 degrees and temperature will not increase.
That seems to me like it could be an issue with the sensor. Ohm it out. It should be around 1100 ohms if it is any good. Check for shorts from each wire of the oven sensor to ground. I have a manual and a TIP I wrote about these Thermadors.
Thermador 301/302 wall oven repair manual
Sep 28, 2010 | Thermador SC302T Electric Double Oven
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Frigidaire PLEF398AC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
