Question about Pool & Spa
My self priming pool pump all of a sudden stopped pumping. It is set to run everyday and one morning it was making a humming sound but wouldn't start. This has happened in the past before so I thought it lost the prime. I filled with water and it worked. But this time I cant get it to work. It starts to hum and then it shuts off. Could the impeller be stuck?
You too can find out my solution for just $ 9.95. I was looking for some advice so I looked elsewhere until I found it. Thank you anyway for your time.
Posted on Jan 15, 2009
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Pool water will not circulate even though pump is running
if the water doesnt circulate, there could be many causes. start at the very beginning. does the pump sound 'normal'? if there is rattling or buzzing, the pump might not be turning and there fore no circulation. is there water in the system? even though most pumps are 'self priming', you should fill the hopper with water to prime it. are the lines open? make sure the supply to pump from skimmer is free of blockage and that the return lines to pool are open and free from blockage. if all this looks fine, then you have to get deeper into diagnosis.
Dec 20, 2015 | Hayward Pool & Spa
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Pump stopped working and looking for troubleshooting tips
What do you mean-"stopped working"?
on and only hums or buzzes? On and running but no water is priming or pumping? Or no sound no nothing at all? If we here in this forum are to help you, we need more details.
Mar 28, 2015 | Pool & Spa
Error after short prime cycle
Apr 21, 2014 | Pentair IntelliFlo VF High Performance 3HP...
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pool & Spa Logo
750 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
