Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
Epson RX680 startup error - Epson Stylus RX680 Color All-in-One InkJet Photo Printer
  • Anonymous Jan 27, 2009
    WHEN I TURN ON MY RX680 I GET ERROR OCCURED RESTART BUT IT STILL DOES NOT WORK, I GET A FLASHING ON OFF LIGHT AND ALL THEE MODE FUNCTIONS BLINK. ALSO I HAVE NO PAPER JAM OR LOW INK CARTRIDGES . HAVE ANY IDEA?
    TAHNKS PETE
After I made sure there was NO paper or foreign objects jamming the printer I was told (By Epson Tech support) when this happened to unplug the printer AC and USB and leave unplugged anywhere from 30 minutes to 2-4 hours and then plug it all back in and see if it works. For the most part it seems to work.....but WHO has time when they need stuff printed NOW to wait 30 minutes to 2-4 hours for a printer to decide to do its job?
Posted on Jun 18, 2009
    President:
  • 2,692 Answers
New problem?Always worked before on this same computer?  Have you tried reinstalling the computer and driver?
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Posted on Jan 14, 2009
  • 14 Answers
SOURCE: I have an Epson RX680 printer. When I turn the
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.
Posted on Apr 26, 2010
giovarodrigu
  • 24 Answers
SOURCE: My Epson RX680 has dust in my display how do I
First question: have you the skills to open the printer?
Second: it is affecting the funcionality?
If both answers are not, then keep working.
If you want to open the printer, find and download the service manual, fin it in google, some places give it free, other ask for a donation and anothers sell all via paypal.Good luck
Posted on Jul 20, 2009
aicaxz
  • 511 Answers
SOURCE: epson stylus photo RX680 error message says;
Yes you're right. Use SSC service utility or RX680 Adjsument program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside.
Posted on Aug 28, 2009
Gort007
  • 1187 Answers
SOURCE: Epson RX680-How to print only in B+W
You can set it to "grayscale" and supposedly print only in black/grey.
However, Epson printers use a small amount of every color even when printing black only or greyscale (black). Your printer will still not work with one color tank empty.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95907
Here is how to set it:
Open the properties page for the RX680 and on the "Main" tab, click on [Advanced]. A Note may appear egarding incorrect settings.
Click [Continue]. Find the [ ] Grayscale box and check it, the [OK]
[OK], etc.
Here is Epson's note on using grayscale / colors:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95908
Posted on Sep 24, 2009
sivaranjini
  • 241 Answers
SOURCE: won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Posted on Nov 25, 2009
My epson rx680 on start up says "a scanner error has occured". See your documentation.
If the rebooting does not do the trick, then the rep is right in telling you that unit is in need of repair. But at what price. Better check that out first since it might be cheaper to replace than repair.
Aug 19, 2015 | Epson Stylus RX680 Color All-in-One InkJet...
CD tray on an epson RX680 gets an error "Tray not set correctly"
Tried everything posted. Happened repeatedly till I finally got mad enough to shove the tray way back in the slot. Works fine.
I love technology.
Bigger hammer theory.
Jan 25, 2011 | Epson Stylus Photo RX680 Printer
Jan 31, 2010 | Epson Stylus Photo RX680 Printer
[OK], etc.
Sep 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
What is specialty print on the epson rx680?
The Specialty Print service on the Epson RX680 allows you to restore colors in faded photos, correct poorly exposed photos, reduce redeye, and even crop while you copy photos.
Aug 29, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson stylus photo RX680 error message says; service required contact epson. Does the counter need to be reset and if so how do I do that?
Aug 27, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Jul 20, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson RX680 Startup Printer Error
I had the same issue when the printer arrived. I powered the unit off, moves the ink cradle to the left about 1/2 " then powered it on. Then it worked from there.
Oct 01, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
568 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
