Question about Gateway FPD2275W LCD Monitor
I have a Gateway FPD1975W TFT LCD Monitor which often works when plugged in to a computer but when plugging it in to my laptop it keeps displaying a green box that says "Frequency out of range" instead of displaying the monitor. This only happens occasionally, usually after a shut down and update and I have to shut down (not restart) before it will work again. I've tried refreshing the "Connect Display" button in the Windows Mobility Center, restarting, and even plugging and unplugging as well as changing the display settings and nearly every combination of these things. I can't figure out what the issue is.
  • 558 Answers
The laptop needs to have the display settings and the adapter or monitor setting changed to a lower freq, like 60 hz
display settings/ advanced/ monitor/ change setting to 60 hz, that should fix ya let me know if it works.
don't forget to rate when its fixed.
Posted on Mar 22, 2009
Where is the microphone
That model does not have a built in microphone, you will need to get an external mic and connect it to your computer.
May 08, 2012 | Gateway FPD1975W 19" LCD Monitor
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
http://en.wikipedia.org/wiki/Capacitor_plague
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a gateway FPD1975W tft lcd Monitor. It will not power on at all. I took the power cord from an exact same working monitor and put it in this one and it still will not power on?
Faulty power PCboard. Reasons and the exact problem may vary. Main components to check: The fuses, the stabilizing capacitors on the low voltage, the impulse transistor, the optron and the pulse width modulator (PWM) IC.
Jun 15, 2010 | Gateway FPD1975W 19" LCD Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W TFT LCD Monitor Need to Resize Screen
Did you try changing your display resolution in your computer display properties ?
Right click anywhere on your screen backdrop, click on properties, go to settings then pick the resolution that fits your screen the best.
Aug 20, 2008 | Gateway FPD2275W LCD Monitor
19 inch tft lcd monitor blurry
go to control panel click on display icon and then go to setting tab and there you will find screen resolution settings
Apr 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
216 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
