Question about Zanussi FJS1225W Front Load Washer
Zanussi FJD1666W heater removal.
What is the best way of gaining access to the heater element. There is no rear access panel so the cover may have to come off. If so, how do I get te cover off without removing every screw in sight?
Any help would be greatly appreciated. Thanks.
  • redroyal Jan 19, 2009
    The part arrived today. Your instructions for removing the cover made the job very easy. Thanks for your help.
  • cliffordwalt Apr 29, 2009
    switch on washer when heater comes on fuse blowes how do i solve this.
  • Zanussi Master
  • 3,463 Answers
There is no easy way to access the heater without stripping it down.
Remove top cover.
Remove 2 scews at rear bottom of cabinet.
Remove 2 plastic covers at front bottom sides of cabinet, and remove 2 screws located in holes, you will need a nut socket to remove them.
Remove inlet hoses, and undo screw at top where the hoses connect to, prize up the plastic retainer that holds the valves in place.
Remove screws at top of cabinet that hold the 2 halves together.
Then lift rear half of cabinet clear of the front.
At the bottom rear you will see the heater element located.
Undo center nut and remove element..
Fit back all parts in reverse order.
Not an easy job. Good luck.
Plz rate my solution.
Posted on Jan 15, 2009
How to repair a zanussi condenser tumble dryer belt
Access from the rear panel to drive belt:
- Remove the worktop
- Remove the side panels
- Remove the rear panel cover
- Remove the motor unit
Oct 03, 2014 | Zanussi TC7102W Electric Dryer
How do I hgain access in order to replace the heater element on my Zanussi dw 905 dishwasher?
You can get details from the manufacturer .
Jun 23, 2014 | Dishwashers
Error code 40
"E40 - error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos, where the door striker pin goes through hole.
*Held on with 2 screws and remove plastic clamp from door gasket to gain access.
*Check the Door Switch/interlock or the WIRING for failure, if there is a problem, repair is necessary."
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question.
Jun 04, 2011 | Zanussi FJD1666W Front Load Washer
Can you replace oven element, cannot see any screws in oven to remove plate to gain access
You will have to remove the oven from the housing, and then remove the rear cover of oven, and gain access to the securing screws for the element from the rear of the oven, you will see how it is fixed once you remove the outer panel of oven
Feb 23, 2011 | Candy FP855 Electric Single Oven
How do i replace heating element in a zanussi washing machine
It depends on the model of washer.
If it has no removeable rear panel, then you have to remove the complete rear half of the cabinet to access the heater, not an easy job.
If it is an early model, then it will have a removeable rear cover, and the heater can be changed from the rear of the washer.
Feb 12, 2011 | Zanussi Washing Machines
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
How to install zanussi dx6452 heating element
disconnect from electric and water supply. remove drain screen from inside dw , mopp up residual water. remove front feet and plinth cover, and right hand side panel. with machine on its back remove rear foot adjustment shaft.and base cover. disconnect wiring to tube enclosed heater. remove hoses very long nosed pliers help to get clips off/on. extract to righthand side. not much space to work here assemble in reverse. good luck
Jul 21, 2010 | Zanussi Dishwashers
How do i strip the element out of my belling fan oven
The element is located at the rear of the oven compartment behind a removeable cover.
If there is no provision for undoing the screws from inside the oven, then you will have to remove the outer rear panel of oven and possibly the top cover also to gain access to the element screws.
Hope this helps.
Feb 08, 2010 | Belling Ovens
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Jan 24, 2009 | Candy Ovens
Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Dec 31, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
202 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
