Question about GE WSXH208A Front Load Washer
GE Front Loader Won't complete cycle
I bought my GE Front loader washer/dryer set used off of craigslist.com. I just used the washer for the first time the other day and it goes thru the wash cycle but doesn't automatically go thru the spin cycle. So I manually put it in the drain and spin cycle and even then, not all of the water was spun from the clothing. I have now used it 3x's and same thing is happening each time. Am I supposed to have to manually put it on the spin cycle? If so, that really bites. But even more so, what could be the reason that it's not spinning fast enough or long enough to get the majority of the water out?
  • 4 more comments
  • eddysgirl38 Jan 23, 2009
    I too, am looking for this answer. My washer does not spin the clothes completely unless it is a very full load. Therefore I cannot was just a few items as I could with my old top load washer. Can anyone help with this problem?
  • Anonymous Jan 25, 2009
    I have the same problem. If I put anything oher than clothes (heavy items like blankets or towels) the full spin will not engage and I get let with a soggy load. I remover the heavy items and it spins out just fine.
  • tandisteffen Jan 26, 2009
    I too have trouble with soggy loads. I thought I was overloading it w/jeans so tried to do an empty load. Still have water left in the thing.
  • tkelley Jan 29, 2009
    I have the same issue with my GE front loader which is about 2 years old
  • Anonymous Feb 14, 2009
    My GE front loader is also about 2 years old. It worked well until about 3 months ago. Now it never spins out the water fully no matter if it is a full or small load. I am very frustrated!
    mschaefs
  • mshafer955 Feb 18, 2009
    Great quick fix. Took 15 mins and I got 3 bucks back out of the drain/filter. I had lost my Oven [Kitchenaid ] and my washer on Super Bowl Sunday. FIxed both problems with solutions I found here. Well done. Hope I can return favor one day. 3 screws and small bucket and done.
My GE Front Loader is 18M old and it has been progressively getting worse, not spinning the water out......I should have known the Pump had a cleanable strainer as Solution #1 says. Pulled a fist size chunk of wet lint, coins, a necklace and wrappers from the Strainer, not to mention about 2 Gal of dingy, soapy water. Tried a Drain/Spin and after a couple of minutes, went to High Speed Spin for the 1st time in about 3 months. Obviously there is a Water Sensor on the Drain Line somewhere that if the Drain Line still has water in it, it does not allow washer to go into Med/High Spin Mode.
Posted on Feb 17, 2009
The 'best solution' (i.e. strainer at the pump) was the ticket. I found $5.93 with an assortment of screws, nails, nuts and washers. The fix took about 20 minutes due to the cleanup. I gotta get in the habit of not putting these items in my pocket. A penny also made it through the system and was blocking the discharge at the sink. The machine is working like new.
Posted on Jun 20, 2009
I have the same problem with mine, but only on the high spin. If you try a lower setting it may work. Medium works for me.
We got ours off craigslist as well, but my hubby's friend dropped his end in transport and we can only use the speed wash setting and cant change it...But that's a seperate problem I suppose.
Posted on Feb 16, 2009
I have had the same problem. It is pretty simple to fix, just unscrew the 3 screws under the bottom front panel and remove it. You will see a lid that unscrews, this is the filter. Just unscrew it and clean it out. Make sure you have a pan and plenty of towels to catch the water that will spill out.
Posted on Feb 08, 2009
Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Mar 28, 2015 | Washing Machines
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
My front loader washer does not agitate during
It is possibly the motor brushes. worst case scenario is the motor complete.
Jul 05, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Mar 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I just got a brand new GE Front Loader Washer & Dryer.
No, but it depends on in part on what cycle you selected. Did you happen to choose one with an extra rinse cycle?
Jan 22, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
615 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
