Question about GE Washing Machines
Water leaking from tube of GE clothes washer WWA7050BALAD
I suspect the tub gasket is the problem. How do I fix it?
techman
  • 3130 Answers
SOURCE: ge washer overflowing/not rinsing or wringing well
if you need parts for any apliance go to www.repairclinic.com They will assist you to find the parts you need .
Posted on Mar 28, 2006
jsrock516
  • 5911 Answers
SOURCE: Water leaking
If it's the hose your talking about, the white tube connected to your tub is called and "air dome" hose. It connects to your pressure switch to shut off your fill valve when selecting load sizes. The hose should connect to a fitting somewhere near the base of the wash tub. If it is leaking, generally mildew inside this tube can cause it slip off it's fitting or lose it's seal. Also the hose can stretch out of shape over time and lose its seal. If you have enough slack in the house, you can pull the hose off the fitting and cut about half an inch off the end, clean the fitting, and reattach. This should reseal it. If the hose itself is leaking, you should replace the entire length of house from the tub to the pressure switch. You can find plastic hose of this type at any hardware store. I hope this helps.
Posted on Apr 15, 2007
  • 1028 Answers
SOURCE: Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Posted on Jun 17, 2008
mikedurland
  • 481 Answers
SOURCE: GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Posted on Jun 27, 2008
SOURCE: GE Front Load Washer
Had the same problem and did 2 things to fix. Remove the bottom panel on the washer(3 screws on bottom front). Just to the right of the center is a white plug that you can unscrew. Before you unscrew, get an 8x8 cake pan underneath to catch the water that comes out(bigger if there is water stuck in your washer). Unscrew cap and take out filter. My filter had pocket change, bandaids, tape, hairpins etc in it(kids do their own laundry and aren't vigilant about checking pockets). Screw filter back in and put panel back on.
Also, lint was drying on washer tub viewing glass where gasket hit it. Gasket wasn't making a good seal there and thats where water leaked out. Clean the dried lint off. No more leaking for me.
Posted on Aug 10, 2008
What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
Aug 04, 2011 | GE WDSR2080D Top Load Washer
My washer started to leak. I removed the front panel. I ran a load of clothes and watched closely. When the machine filled and started to agitate I noticed water coming front what to me appears to be some...
Hello litespeed102,
When you observed the agitation cycle did you hapen to notice if the inner tub was rotating during the wash cycle(not spin) if so the brake that is a internal part of the transmission isnt locking down the tub, and what is happening is water is coming from that tube due to centrifugal focre of the the tub rotating causing the water to rise to the level where it will enter into that tube. The only fix for that is to replace the transmission,which would cost more that the purchase price of the machine,over time it will get worse and while it may be only moderate leakage now later it it will be 1/2 of the waterin the tub if not more leaking from directly over the tub cover and just not merely from that tube
Jul 22, 2011 | GE Washing Machines
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
My washer will not stop filling. it will continue to fill and overflow. What do I do?
Hello there:
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 03, 2010 | GE WJRR4170E Top Load Washer
I have a GE model WHDRE526E1WW washmachine.The complaint was it would not spin. I checked the agitator coupler and the washmachine agitates but won't spin or fill with water. I suspect it may be the...
Try suspecting the tub end of the water level tube being plugged with " goop " so that the washer thinks it is still full of water, thus will not fill or spin. Take the front panel off by releasing the push in clips at the top of the front panel, in the seam where it meets the washer's top. Now, find the tube at the left side of the outer tub and pull it off the tub. Clean it out or cut off an inch (don't do the cutting thing more than one time) and replace after using a thin wire to clean out the tub end of the attachment. To help prevent this from re-occuering, every few months, fill the washer to the lowest setting with the hottest water, no clothes, and several cups of bleach, and run the longest cycle you have (with no clothes, of course). Make sure to rinse out the tub on a higher water level before you wash a load of clothes.
Sep 06, 2009 | Washing Machines
Our washing machine overflows when it is filling with water in the small load cycle.
Check these:
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | GE Washing Machines
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
My Ge washing machine is leaking from the Bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
GE Top-loader Leaks Water from Vert Tube Behind Tub on X-Large Loads
During fill only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 18, 2008 | GE WBB4500EWW Top Load Washer
Jun 17, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
54 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
