Spin cycle died
When i put the washing machine onto the spin cycle the little lever that locks the lid down moves over but the drum does not spin but you can smell a faint burning smell any help pleses
  • 15,935 Answers
Check the drive belt for proper tension... or the coupling for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Good afternoon my wash machine Samsung WA17x7r does not spin anymore. Everything else work perfectly, except it doesn't spin nor for washing, rinsing or drying.
First thing to check would be your safety lock switch, see if it's engaged, can you open lid while still set on cycle? It shouldn't open. Sometimes they bend a little, no latching, won't spin, or a loose screw needs tightened.Sometimes the timer switch can be a little off. Pull off your knob that sets the cycles and see if it is in true line up with function. If not, I think I remember you can adjust it from behind panel.
Feb 17, 2017 | Samsung Washing Machines
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
Feb 08, 2016 | Simpson Washing Machines
My washing machine drains,but when on a cycle the drum doesn't move at all and it doesn't go into spin mode?
Check the actuator for the lid switch to make sure it isn't bent or broken. To find the lid switch, look for a pin on the lid that goes through a hole in the top of the machine when the lid is closed. The lid switch actuator is under this hole. If you can't see the actuator lever through the hole, it's probably bent off to the side or broken off. It's also possible to see it, but it's bent down to far to be actuated by the pin. If the lid is bent or the pin is broken off, that would have the same effect.
Apr 04, 2012 | Washing Machines
I accidentally loaded it unevenly and when it hit the spin cycle the whole machine jumped all over the place. Now the machine just fills up but doesn't agitate or spin. just fills up and drains!
The load probably caused the machine to shake so violently that the belt has come off the drum (can you hear the moror quietly whirring when it should be agitating)
Step 1, as always, unplug from the mains.
Most hotpoint machines have a removable plug on the side of the lid towards the front (A little smaller than your little finger nail). slip a knife behind the plug and gently lever it out (it has 2 little pins that fit holes in the lid) Once removed, you will see a torque screw (Star head) is revealed. Unscrew this screw on both sides.
lift the front of the lid very slightly and then strike the front surface hard with the heel of your hand, pushing it backwards about a cenrimetre to disengage the clips at the back of the lid.
It now lifts off.
Look down the back of the machine, you will see the big pulley that is attached to the back of the drum and almost at floor lever, you will see the grooved shaft of the pulley on the motor. Somewhere, you will see the black belt, lying on the floor.
Take the belt and put it back over the small motor pulley, then hold the belt in place where you want it on the big pulley. Slowly turn the large pulley, so that the belt slips back in place. spin the pulley a few times and make sure it is lined up on the big pulley nice and evenly. If it is a bit out, you may need to go back or forward a groove on the motor pulley to line it up.
Once you're satisfied this is done, rin the machine on a spin cycle (with the lid off and an empty drum). The belt should stay on and all should be well. If it is, put the lid back on and the job is done.
Feb 26, 2011 | Hotpoint Washing Machines
I tried washing a rug - I believe it was too heavy and moved the washer around during the spin cycle. Now it is not spinning, it make the sound but it won't turn - I can move the tub around with my hand...
Hello- First unplug the washer. The out-of-balance switch may have gotten tripped. If you open the lid and look in the space between the tub and the top in the rear right corner you should see a plastic "arm" sticking down, reach you hand back there and move it back away from the tub. This lever actuates a switch in the control panel that will prevent it from spinning if there is pressure on it, it should be hanging freely away from the tub. Plug the machine back in and test it. If it doesn't work another thing that may be happening is the tub is not engaging on the transmission. With the tub empty reach inside the top perimeter of the tub and lift it up and let it down a few times, sometimes this will reset it and get it to spin. Lastly, i would check that the lid is locking when you put it into spin, the lid lock light should come on and you should not be able to lift the lid. If the lid is not locking you may need to have a F/P Tech out to replace the lid lock. You can test the spin by setting the machine to Permanent Press and advancing the cycle to spin. It will take a few minutes to start spinning usually. Let me know what you discover, good luck. Best regards.
Sep 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Lid lock not on, and machine is not going through
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Our washing machine was stopping at various stages & would beep and just not continue with the cycle. (Sometimes it would fun a full cycle without a problem however). We took it to an official...
The drum suspension rods may be worn or one of them may be brocken, throwing the drum out of balance.
They are fairly easy to change if you know how to open the top hatch. Check and remove them individually.
Let me know if you need assistance or more info.
Ash
Oct 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
